Polk Audio CRS + (RDO198) Crossover Modification Thread
VR3
Will post some misc pics on this as the build progresses -
Specs are -
External build, custom mounting plate for the back of the speaker
Clarity Cap CMR 400v
Duelund CAST Resistors
Jantzen Inductors + C-Coil
Supra Rondo Internal Wiring
Point to point
WBT Binding Post
DH Labs Q-10 SDA Cable
Specs are -
Point to point
WBT Binding Post
So looking forward to your illustrated progress on this.Home Theater
WOW!
Can’t wait to see the finished project.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Where are the installation pics?
Hasn't left this side of the pond yet, have a part for Sean coming then they ship out
Be sure to take some pics.
President of Club Polk -
sounding tight
Bet the low end sucks.....
Actually, not really. The bass is great with the drivers half towards the floor.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Ive always been surprised how the mods sound free air, when you leave the room, you can hardly tell they are free air versus in an enclosure. The bass is not as forceful or the impact but it is there.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
What's the reason for the caps being on the outside?
They wont fit inside
Some people also feel external crossovers sound better since they are not exposed to much vibration... ymmv - Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Bad news ,The fedex plane carrying my xovers that Vr3 built crashed around a week ago.
Good news though , the only two box's that were retrievable at the crash site were mine due to their packaging.
Im a little busy right now but i will bang some pictures up when i start the project! -
Ok. Got a lunch break in and installed these x overs. Thank you again to Trey and Dave for your excellent services
Pictures to follow.
Mmmmm. Cant load them from iPhone. B.B. L -
Looking forward to them..
I've seen pics, they look like terminators- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
the stands slightly modified from Larry's specs so as to not breech copyrights .19 kilo's of lead shot
The Notorious Larry's Rings. I find them to be even better after glueing them in, more so in the SRS's.I just wiped power grab along the edge internally making sure that none enters the threaded area.....so how many inch's of steel are in the SRS'S installed with theses rings..? I lovem.
Very nice Sean! Enjoy them!Home Theater/2 Channel:
dhsspeakerservice.com/ -
I see you got the labels off.
Those look bada$$.
I thought the factory enclosures could possibly benefit from a front to back cross-brace. Will you reinforce the area you cut out?
Looks great.Don't take experimental gene therapies from known eugenicists.
https://youtu.be/2y7Ne5n9we8
