Sonance
tonyb
tonyb Posts: 33,072
Any you guys have any experience with their amps ? Sound quality ? I'm thinking of separating my 2 channel from the HT side, and looking to power 3 different sets of speakers. I'm looking at this....
https://chicago.craigslist.org/nwc/ele/d/sonance-6-channel-power/6481372152.html
to cover outside patio/deck/and inside 2 channel.
    nooshinjohn Posts: 25,919
    Made of solid metal... I see ventilation slots all over the place, so clearly it is not solid metal.
  • FestYboy
    FestYboy Posts: 3,861
    Tony, I asked the same question a couple months ago and was told they are commercial home audio amps, akin to NAD in their performance. I haven't been able to pull the trigger on one yet to give you a personal impression.
    Clipdat Posts: 13,095
    At only $100 it's a gamble worth taking, imo.
  • rooftop59
    rooftop59 Posts: 8,121
    Tony, I have had almost the exact same amp (a 260x3, 60 wpc channel for 3 pairs of speakers) as my zone two amp for 7+ years, using the auto on, never had a problem. Powering a pair of rt25is on the patio, sounds great for outdoor tunes when you are grilling, etc. Also runs a pair of in-ceiling polks in the living room.
    I wouldn't use it as my main amp, but for zone two, garage, even surrounds, I think it works great.
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 33,072
    rooftop59 wrote: »
    Good to know, but whats the downside, sound wise, as why you wouldn't power your main 2 channel with it ?
    I'm trying to separate my HT from the 2 channel, but where I need to set it up it also has to run 2 pairs of outdoor speakers. For the 100 bucks, it almost seems like a no brainer, especially if you compare it to a Nad.
  • FestYboy
    The biggest I see pop up on fleabay are the 2120s (2×120w), so for mains, they may not be big enough, but they are stable at 4 ohm... For a budget rig, they're cheaper and easier to find than NAD, and I suspect that they could be upgraded if one was so inclined.
