Rm 6800 subwoofer
buede
I just bought this theatre system and have all hooked up except the sub. What kind of cable is needed to hook the sub into the receiver? This sub has 2 output connections not like the usual one??? Please give me the presise brand and model if possible..
Anxious to hear the system!!
Post edited by buede on
A single cable with rca connectors is all that is needed. If you want, you can add a splitter on the end to plug both inputs on the sub.
Regards,
PolkThug -
PT,
You must either be psychic or have a decoder ring I don't own...More later,
Tour...
Vox Copuli
Polk would recommend using speaker wire...
