Rm 6800 subwoofer
buede
buede Posts: 1
I just bought this theatre system and have all hooked up except the sub. What kind of cable is needed to hook the sub into the receiver? This sub has 2 output connections not like the usual one??? Please give me the presise brand and model if possible..
Anxious to hear the system!!
Post edited by buede on
  • PolkThug
    PolkThug Posts: 7,532
    edited November 2004
    A single cable with rca connectors is all that is needed. If you want, you can add a splitter on the end to plug both inputs on the sub.
    Regards,
    PolkThug
  • Tour2ma
    Tour2ma Posts: 10,177
    PT,
    You must either be psychic or have a decoder ring I don't own...
    More later,
    Tour...
    Vox Copuli
  • fireshoes
    fireshoes Posts: 3,167
    Polk would recommend using speaker wire...
