Thinking about going tubes
124
    tonyb Posts: 33,072
    Looks like a great start to me.
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Schiit Saga and Freya worth checking out from a cost of entry standpoint.
    Hello everyone, been following this thread. I too am thinking about taking the plunge or just dipping my toes in.
    Anyone have any experience with the Schiit pre's??? Not a whole lot of in-depth reviews out there yet.
    Schitt Freya for 700 bucks??? Holy Schiit!!!
  • stangman67
    stangman67 Posts: 2,329
    I know there is a few on this board that have Freyas. Hopefully they will jump in, I thought for a brief second about trying one out but I haven’t heard the best about schiits sonic qualities.
  • stangman67
    Yea big surprise, Schiit doesn’t sound good lmao
  • Well, I have a Saga pre that I use w/ my Dynakitparts ST-35 and Pass designed AmpCampAmps (class A mono-blocks). I think it sounds great! Now I did swap out the stock tube (not that it's all that bad) for a nice old Sylvania 6SN7-GTA, which improved the sound stage.
    Tell me where else you can get a pre that operates as a passive or a tube buffer w/ relay stepped attenuator, remote control, 5 inputs and 2 outputs that sounds great for $349?
    And if you haven't heard it, then you don't know! Of course, if you have the bucks to play in the big leagues, I'm sure you can get better sound for $20K. Personally, I can't afford to go there.
    Cheers, Jim
    A day without music is like a day without food.
    tonyb Posts: 33,072
    lol....lots of real estate there Jim....between 350 bucks and 20k. :)
    Clipdat Posts: 13,095
    Nice Jim, thanks for sharing your thoughts.
    I've just been using my Saga in passive mode with no tube installed, just to get a baseline idea of it's performance. I'm loving the accuracy of the relay-stepped volume control! Makes you never want to use a traditional volume pot again.
    Cheers, Jim
  • verb
    verb Posts: 10,176
    Cheers, Jim
    Ditto @clipdat on your thoughts. I read a lot of folks do indeed roll the tubes with better results. But what "tubie" or "tuber" not sure of the moniker, doesn't? If your gonna test the waters, seems like this would be the schiit.
    edited January 2018
    I actually discarded the stock tube without trying it, after reading about how bad it was. Clearly they were just interested in including a tube to give it basic function. Hey they had to get to that $349 price somehow.
    I'd rather spend $30 on an entry level tube, even new production, versus using something that isn't balanced and probably has microphonics.
    verb wrote: »
  • verb
    verb Posts: 10,176
    I'm hoping some of our esteemed CP tubies will opine on the Schiit Freya. I have learned to respect their opinions and of course laugh at their jocularity. Come on @tonyb give us the schiit!
    edited January 2018
    They Freya was originally on my radar, but I went for it's smaller cousin due to a few reasons.
    The Freya's 14db gain on the tube stage seemed like it would be too much for the quieter listening I tend to do. I think the Saga's 0db/unity gain approach is a better implementation.
    $350 price difference.
    4 6sn7 vs. 1 6sn7. Quite a bit more expensive to roll matched pairs/quads vs singles.
    verb wrote: »
  • verb
    verb Posts: 10,176
    DSkip wrote: »
    No tube amp manufacturer should invest in expensive tubes for the base amp. Some will offer upgrade paths which is a plus but to force customers to spend dough on a tube they may not even want.
    That makes sense. I like the idea of swapping tubes to experiment. A lot easier than desoldering/soldering caps, resisters, etc., on a SS pre.
    mhardy6647 Posts: 35,030
    verb wrote: »
    tonyb Posts: 33,072
    DSkip wrote: »
    Probably right....but Joule's came with decent nos tubes in them.
    tonyb Posts: 33,072
    Can't comment on the schiit Pre amps, never heard them myself. Their dacs though, did nothing for me.
    txcoastal1 Posts: 13,513
    tonyb wrote: »
    DSkip wrote: »
    Sometimes you have an ear and like the manufacturer/designer and can most always like what they produce
    I like Modwright
    Have spoken to Dan several times, and owned a few pieces of his gear. So far none have failed me when they got home.
    I've repeatedly heard that their DACs (Bifrost specifically) are very clinical and sterile sounding and need 100+ hours to begin to sound "good", and even then, still very clinical and sterile.
    tonyb wrote: »
    edited January 2018
    Clipdat wrote: »
    Very clinical and sterile before break in; very clinical and sterile after break in... begging the question "what changes when they 'break in'?" ;)
    One is tempted to try one of them there Sagas, you know? :)
    Not quite cheap enough to just try on a lark, though.
    One expects to be getting a chance to try one of their little Mani phono preamps anon (one is pleased to report).
    It's like you start out in the ER and then you get admitted and they give you a room.
    Clipdat wrote: »
    ... and, and... they put you on an IV antibiotic drip!
    Nice analogy!
    audioluvr Posts: 5,916
    ... squirrel!
    tonyb Posts: 33,072
    txcoastal1 wrote: »
    tonyb wrote: »
    DSkip wrote: »
    I like Modwright
    Modwright is a company that, in my opinion, gets overlooked. Dan looks to do fantastic work and his mods on other brand pieces are nothing to sneeze at. He has a following for a reason.
    Just thinking....we should put together a list of great companies to deal with and the great people behind the curtain. People just stepping up their game have no idea of all these companies or where to go. Especially considering the amount of Boutique brands out there these days.
    Viking64 Posts: 7,559
    tonyb wrote: »
    If you place a Halloween tablecloth on a teak table, would that be considered.....BOO TEAK?
  • verb
    verb Posts: 10,176
    tonyb wrote: »
    txcoastal1 wrote: »
    tonyb wrote: »
    DSkip wrote: »
    I like Modwright
    GREAT IDEA!
    verb wrote: »
    GREAT IDEA!
    HEY YOU!!!! STOP YELLING!!!!
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    verb wrote: »
    GREAT IDEA!
    great idea.
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    verb wrote: »
    GREAT IDEA!
    verb wrote: »
    great idea.
    I'm sorry, what was that? I was just listening to Deep Purple quite loudly and my ears are ringing. :p
    Viking64 wrote: »
    verb wrote: »
    GREAT IDEA!
    https://youtu.be/ohXOOzZCDWw
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    verb wrote: »
    great idea.
