end picture
amulford
That's standard for the Polk Cobra Cables. Have you hooked them up?
I used my pair with the stock 'fangs'. If you do re-terminate, I'd go for a crimp / compression job, vs getting other metals in the mix.
Check PE for crimp / comp jobbies, if you want to go hardcore, WBT or Vampire Wire is the order of the day.
Cheers,
RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
