end picture
amulford
amulford Posts: 5,020
edited November 2004 in Forum Testing Area
Here is what they look like Russ
  • RuSsMaN
    RuSsMaN Posts: 17,985
    That's standard for the Polk Cobra Cables. Have you hooked them up?
    I used my pair with the stock 'fangs'. If you do re-terminate, I'd go for a crimp / compression job, vs getting other metals in the mix.
    Check PE for crimp / comp jobbies, if you want to go hardcore, WBT or Vampire Wire is the order of the day.
    Cheers,
    Russ
