Vintage Monitor and SDA Speaker Deals
1109110112114115259
  • Just posted 16 hour ago - For all those living in SoCal, there is someone clearing out what appears to be a very large storage area of vintage Hi-Fi gear, including a pair of POLKAUDIO RTA-12C SPEAKERS. He has A LOT of gear! Wow.
    https://orangecounty.craigslist.org/gms/d/vintage-audio-equipment/6474332949.html
    No Affiliation
    HT
    Adcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).
    2 Channel (Living Room)
    Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.
    2 Channel (Office)
    Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).
    2 Channel (Garage)
    Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
  • For anyone in SoCal looking for vintage gear, the seller appears to have A LOT that he needs to unload! Including a pair of POLK AUDIO RTA-12C SPEAKERS
    No affiliation.
    HT
    2 Channel (Office)
    2 Channel (Garage)
  • ken brydson
    ken brydson Posts: 9,020
    4X. Must be good, lol....
    Tony M Posts: 11,720
    Man, I'm sad and glad I live 3,000 miles away!!! ;) more glad though.
    I'd want to spend a couple of grand easy. B)
    WOW
    nooshinjohn Posts: 25,996
    INFINITY RS II REFERENCE STANDARD vs Polk SDA 1.2... which one wins?
    I am looking at grabbing the Infinity RS2 from the CL down in Orange County. which speaker would win head to head?
    EndersShadow Posts: 17,719
    Polk. My RS-II didn’t really do very well with rock and roll at all.
    They do good with vocals and instruments though
    did yours look like these?
  • Jaybeez
    Jaybeez Posts: 748
    You're not considering getting rid of the SDAs are you?
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
    Perhaps... I miss the Magnepan MG20's I had, but they lacked the punch the Polks have.
  • Those are the RS-II’s he has. Although they need some love (need new surrounds on all 4 woofers, and a lot of Renaissance Wax!)
    HT
    2 Channel (Office)
    2 Channel (Garage)
  • He was asking $500 for the RS-II’s.
    HT
    2 Channel (Office)
    2 Channel (Garage)
    Yes John those are what mine looked like
  • And one of the RS-II’s needs a new grill frame
    HT
    2 Channel (Office)
    2 Channel (Garage)
    pitdogg2 Posts: 27,296
    Smallies wrote: »
    TNTsTunes wrote: »
    Smallies wrote: »
    Oooo that isolation cable is worth 100.00
    and it's already in the bag because he can't use it with his tweeters.
    Tweeters have nothing to do with that cable and it is designed for 2.3's which all are pin/blade designs.
    Wrong again junior you see if you remove the cable you can use sl2500's I tried it on my sda2's. If you connect the cable the tweeters get totally screwy.
    Hmmmm
    I think somethings wonkie .......
    The cable has nothing to do with the tweeters. The tweeters are not in the SDA circuit not since there was blade/blade cable and dimensional tweeters.
    The AI-1 cable was made for all pin/blade SDA's whether or not the had sl2000,sl2500 or sl3000 tweeters
    That cable could also be used on a select few blade/blade speakers with the proper adaptor piece. Once again none had dimensional tweeters.
    If you used it on SDA2 speakers with the dimensional tweeters i bet it did get wonkie since they are a Blade/blade design and that cable was never made to be used with those to begin with since both blades carry a larger bandwidth signal that the pin/blade does not.
  • TNTsTunes
    TNTsTunes Posts: 751
    Smallies wrote: »
    TNTsTunes wrote: »
    Smallies wrote: »
    Try again.
    You are comparing apples to oranges... SRS 2.3's don't have the wonky SDA tweeters like early SDA 2's do.
    Mathew Polk stopped using dimensional tweeters after producing the early SDA's like you have. He did it for a good reason too.
    When discussing 2.3's the tweeters have nothing to do with the interconnect cable, just like I previously stated....
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • TNTsTunes
    Smallies wrote: »
    I'm not saying it's perfect at all but it makes music if you have destroyed 2000's for example.
    My question is why. SL2000's aren't hard to find, I have well over a dozen of them just laying around in boxes.
    The SL2500 is not the correct upgrade for the SL2000, and they are not compatible with your crossover.
    They are your speakers however and you are free to do whatever you'd like to with them.
  • kcoc321
    kcoc321 Posts: 1,788
  • dkfreebird
    dkfreebird Posts: 1,186
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • dkfreebird wrote: »
    It is a nice deal. The photo shows SL3000's, not the RD0-198's. Wish I lived closer.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • dkfreebird
    I sent him a message about that to see if maybe he installed them after the pics. I don’t need them but you never know.
    Oppo 103
    Pangea PC
  • scubalab
    scubalab Posts: 3,105
    kcoc321 wrote: »
    These are too nice looking to not go to a polkie.
    LS50 $100
    https://seattle.craigslist.org/see/ele/6477936616.html?lang=en&cc=us
    Always loved that rosewood finish. These speakers were IMO one of the nicest looking speakers Polk sold. I've always wanted a pair, but these are on the wrong coast...
  • ken brydson
    kcoc321 wrote: »
    LS50 $100
    @kcoc321 , nice to see you posting again. I'm still rocking the LS90's you steered me to.
  • kcoc321
    kcoc321 wrote: »
    LS50 $100
    Thanks Ken... been busy, but looking to fix up some CRS's, so getting my research on :)
  • Jaybeez
    Jaybeez Posts: 748
    Likely missing inter connect cable(s): https://sandiego.craigslist.org/nsd/ele/d/polk-audio-sda-crs-vintage/6478255893.html
    No affiliation
    WiiM Mini
    Jaybeez wrote: »
    WOW!
    Always 3,000 miles away from me...Why Lord, why?
    audioluvr Posts: 5,987
    Nice looking LS 70's. I how do these compare to my RTA11t's? Maybe I should go check them out.
    https://portland.craigslist.org/clk/ele/d/classic-polk-speakers-pair-ls/6478943854.html
  • verb
    verb Posts: 10,176
    Tony M wrote: »
    Jaybeez wrote: »
    WOW!
    2300 miles for me. I got a head start dude!
  • ken brydson
    audioluvr wrote: »
    70's were the ugly stepchild of the LS series IMO. The larger drivers sounded bloated, midrange not as smooth as the 90's and 50's.
  • Rrusse11
    Rrusse11 Posts: 116
    Nice looking pair of SDA 1Cs, but I have no idea about the pricing.
    Asking $550 obo, deal? fair? over the top?
    Cheers!
    https://baltimore.craigslist.org/bik/d/polk-audio-sda-1c/6455604735.html
    SDA SRS 2.3s
    Pair of Carver TFM 35s
    Carver C-1 Preamp
    CAL Icon MkII CD
    RTA 12s, need major work
  • verb
    verb Posts: 10,176
    Rrusse11 wrote: »
    Cheers!
    Fair price IMO. Sounds like negotiable though. I paid 3 hundie for a set way rougher than those!
    http://forum.polkaudio.com/discussion/179960/another-1c-upgrade-path/p1
