Another 1C upgrade path
Hurricane nuts? Is that like freeballin' in severe weather conditions?
LOL !!! For those NB's like me to CP and missed out on Larry's Rings, gotta let just em hang out. Dang it's cold !!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
So took a break from bantering on CP and decided to drill out the cabinets and prep for H-nuts. Special thanks to @westmassguy for the proper procedure:
The only thing I would add is definitely go slow !!! In fact, I just allowed the weight of my cordless drill to do the cutting. Worked great !!!
Sneak peek. Zebrawood panels for the sides. 1/4" thick, just need to cut on my tablesaw to the correct size.
Ignore all the materials and tools in the background for the home remodel projects now on hiatus in favor of my 1C upgrade !!!
Good advice.
One of these days I'll get around to installing the Larry's rings I have stockpiled. I have 5 pairs of speakers waiting for them. I think I'm short one set of rings for 10" passives, I should have a bunch of extras otherwise."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Good advice.
Dibs on your extras !!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I love Saturdays !!! Rockin Disturbed Immortalized on my 2B's while playing with the 1C upgrade. Finished drilling out the holes for the H-nuts:
Wow!
New MW6511 replacements from Polk arrived today !!! Ready for Dynamat Extreme !!!
Side discussion below on Polk's replacement of the original vintage MW6511:
http://forum.polkaudio.com/discussion/180073/mw6511-6503-anyone-using-modern-replacements-update#latestBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Getting ready to cut the side panels on the table saw.
Remember measure twice, cut once.
"I cut it 3 times and it's STILL too short."Getting ready to cut the side panels on the table saw.
Remember measure twice, cut once. -
Be sure to relieve the rubber surround where the screw goes. If you do not it will pull on the surround and ruin to driver. Sharp razor
This! -
Thanks @pitdogg2 and @deronb1 !!! Answered questions not yet pondered, or asked. You guys are good !!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Yeah!!! Dynamat extreme arrived today. And sonic barrier - thanks @westmassguy. Can't wait until the weekend. Work keeps getting in the way of my upgrade path!!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Dynamat and Sonic Barrier before cutting:
Zebra wood side panels cut to size:
Very nice!!Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Yes indeed very nice. That zebra wood should look real sharp as side panels. Things are starting to take shape.Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
Cool looking panels!Gustard X26 Pro DAC
What type of wood are you going to use for the top & bottom caps?Denon AVR X4200W
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Infinity bu2 sub
Haven't decided yet.- Walnut in natural finish
- Oak in dark stain
- Maple in natural finish
/\/\/\Agreed./\/\/\ I don't think you could go wrong with either.
I personally have always liked the look of the lighter woods.Denon AVR X4200W
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Infinity bu2 sub
I would go with the dark colored end caps personally. Walnut with some lighter grain marks would be sweet.
From the looks of the side panels two appear to have a darker grain pattern and two are seem lighter. If it was me I would personally install the darker ones on the outer facing sides of each speaker and the lighter ones on the inside of each speaker so they face each other.
I would also install the first and third panels the way the grain is shown above(left to right). The second and forth panels would the be reversed/flipped to match.
I'm a bit picky/weird about things like that...
Verb,
Nothing personal and in my opinion. I've seen countless attempts at doing what you are planning and not one of them looks right in the end. The only one I've seen that looks right is a pair of 3.1TL's that were veneered to look like a studio version.Political Correctness'.........defined
President of Club Polk -
Verb,
I basically agree. If he only did a single strip like the SRS 2's, 1.2's or 3.1's use it would probably look better. That's just my opinion also, your results may vary.
Verb,
Yep. As you forewarned me before. I’ll let you know how it turns out!!! Thanks as always for your guidance.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I’m with you on that. The grain being so pronounced definitely needs to be matched for a good symmetry. Thanks for your suggestions!!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Yep. So many choices. Maybe I’ll let my Honey decide as she thus far has zero interest in this project!!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Verb,
I thought about the single strip but decided to go full panel instead. My strategy is to ensure the front edge is aligned perfectly with the cabinet as to keep the relationship the same with the grille. I appreciate your feedback!!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Verb,
Am I repeating myself........oh God, it's started.Political Correctness'.........defined
