MW6511 / 6503 Anyone Using Modern Replacements - Update ?
13»
    pitdogg2 Posts: 27,918
    verb wrote: »
    Yep agreed they could also be bucking magnets. Problem is they change the speaker parameters, thus the performace?
    Nope only the flux field it will not add bass or anything else that I'm aware of. Many many drivers had those that would be anywhere near a CRT. Most would also enclose all that in a metal dome that went over they whole magnet assembly.
    antepli10 wrote: »
    Do LS50 and CS 350 use 6510 and 6511?
    Nope
    F1nut Posts: 52,406
    Adding to the fray, those are indeed bucking magnets, which were very common back in the CRT days. They do not alter the performance.
    Very important, do not try to remove them as you risk damaging the driver.
  • 250GTLusso
    @antepli10 , regarding the IC, only the Pin carries the signal in the Pin-Blade IC (the blade is there to improve retention in the socket). Only the earlier Blade-Blade IC had signals in both conductors.
    You can make a temporary IC with an RCA cable and clipping off the petals, and inserting the pins into the sockets, while you make preparations for the Neutrik SpeakONs (they way to go).
    HT
    Adcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).
    2 Channel (Living Room)
    Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.
    2 Channel (Office)
    Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).
    2 Channel (Garage)
    Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
  • verb
    verb Posts: 10,176
    Thanks for the insight! Father! :wink:
  • kickngas
    Resurrecting an old post with an FYI.
    I just called Polk and the rep said there are no replacements for the MW6510, MW6511, or the "direct replacement" RD6110-1 in stock. Assuming this is indefinite. He recommended I call Midwest Speakers....uggghh!
    Apologize if this has been covered elsewhere.
    Ebay is your best bet.
    F1nut Posts: 52,406
    kickngas wrote: »
    Polk is no longer selling replacement parts for their vintage speakers. Midwest is the source for those now. However, instead of offering each MWxxxx driver model they are offering a one model fits all. Therefore, if you want the correct model you need to shop eBay as Ivan suggested.
  • kickngas
    "However, instead of offering each MWxxxx driver model they are offering a one model fits all."
    So much for having the correct impedance! Crossovers will surely work in harmony with this effort. :#
    See there you go picking up what we're putting down....
