WTB 2 or 3 ch power amp for LSiM home theater
hlshure
I recently upgraded my home theater and I am running LSiM fronts (707/706) off a Yamaha rx-a 2070. Looking to enter the world of power amplifiers and pick up my first amp, either a 2 ch for my 707’s or a 3 ch to include the 706.
Running 5.1.4, Yamaha RX-A 2070, Parasound A31, Polk LSiM 707 (Fronts), Polk LSiM 706 (Center), Polk OWM3 (Surround), Polk TL3 (Atmos), HSU VTF-2 MK4, Epson 5030UB, Silver Ticket 110"
I'm using a Parasound A31 to power my front 703's and 704. They sound great. I was using a Yamaha RX-A2010 for the front 703's then I purchased a Parasound 2250. The sound really opened up. The A31 then took everything to a new level. Parasound amps and LSIM"s are made for one another. Just my 2 cents worth.
Appreciate the input. The A31 is what I would get if money wasn’t an object, but unfortunately that’s out of my price range. I bet it sounds amazing.Running 5.1.4, Yamaha RX-A 2070, Parasound A31, Polk LSiM 707 (Fronts), Polk LSiM 706 (Center), Polk OWM3 (Surround), Polk TL3 (Atmos), HSU VTF-2 MK4, Epson 5030UB, Silver Ticket 110"
Where are you located, and what is your budget?Home Theater
I’m in the Los Angeles area and looking to stay around $1k but might be able to scrounge up a few more dollars for a really good deal.Running 5.1.4, Yamaha RX-A 2070, Parasound A31, Polk LSiM 707 (Fronts), Polk LSiM 706 (Center), Polk OWM3 (Surround), Polk TL3 (Atmos), HSU VTF-2 MK4, Epson 5030UB, Silver Ticket 110" -
Man some of the better amps out there weight 40-80 lbs! Not a problem to ship...However, see what you can find local.... WAIT! you're in LA! There's ALWAYS stuff on CL in LA!
Parasound 2003A
https://losangeles.craigslist.org/sfv/ele/d/parasound-hca-2003-high/6424009549.html
ATI 1505
https://losangeles.craigslist.org/lac/ele/d/fs-ati-atchannel-power/6445571866.html
Sunfire Cinema Grand
https://santabarbara.craigslist.org/ele/d/sunfire-cinema-grand-amplifier/6447096757.html
Sherwood Newcastle A-965
https://inlandempire.craigslist.org/ele/d/sherwood-newcastle-965-7ch/6449535161.html
Cary Audio Design Cinema 7
https://orangecounty.craigslist.org/ele/d/cary-audio-design-cinema-7/6439418885.html
Monster MPA-5150
https://inlandempire.craigslist.org/ele/d/monster-mpa-5150-multi/6438286115.html
Then there is Offer Up!
Anthem MCA50 - https://www.anthemav.com/downloads/MCA_Series_DS.pdf
https://offerup.com/item/detail/379536289/?ref=Search
ATI 1505
https://offerup.com/item/detail/403333159/?ref=Search
Parasound 2003A
https://offerup.com/item/detail/355252683/?ref=Search
Several powerful amps in your area!2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Parasound 2003A
ATI 1505
Monster MPA-5150
ATI 1505
Parasound 2003A
@WLDock thank you so much! I’m leaning towards the parasound 2003A. Which one would you recommend out of the bunch?Running 5.1.4, Yamaha RX-A 2070, Parasound A31, Polk LSiM 707 (Fronts), Polk LSiM 706 (Center), Polk OWM3 (Surround), Polk TL3 (Atmos), HSU VTF-2 MK4, Epson 5030UB, Silver Ticket 110" -
The Parasound 2003A or the Anthem MCA50 I would look at.
Then, the ATI 1505, the Sherwood, and the others.
So many to choose from.
Walt2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Thanks Walt. Another question for you, with any of these older amps, how do know what the lifespan is on these? What typically goes out on them first and what kind of cost might I be looking at to repair an amp like these? I know that’s kind of hard to answer, but I’m just looking for a general idea.Running 5.1.4, Yamaha RX-A 2070, Parasound A31, Polk LSiM 707 (Fronts), Polk LSiM 706 (Center), Polk OWM3 (Surround), Polk TL3 (Atmos), HSU VTF-2 MK4, Epson 5030UB, Silver Ticket 110"
Most amps can last 15-20 years before needing some work done. Obviously that depends on how they were used, how often, or abused.HT SYSTEM-
lsi 9's -
Thanks @tonyb.Running 5.1.4, Yamaha RX-A 2070, Parasound A31, Polk LSiM 707 (Fronts), Polk LSiM 706 (Center), Polk OWM3 (Surround), Polk TL3 (Atmos), HSU VTF-2 MK4, Epson 5030UB, Silver Ticket 110"
