New (to me) amp: McCormack DNA-125
The only other things plugged into the same outlet were the preamp and CD players. Other outlets in the room have clock radios plugged into them that's it.
There's a florescent light in the kitchen, I tried it with the light both on and off, no effect on the hum. No dimmer switches anywhere in the apartment.
And yeah I'll try it tonight with just the amp plugged in with nothing attached to it, and I'll try it on an outlet in a different room.Try the strip just for reference, but, keep in mind that many of them will restrict quality power and you're better off plugging directly in to the wall in most cases, especially with an amp. Not sure what else is plugged in to that outlet, but, I would start eliminating pieces one at a time. Unplug a piece and see if the hum goes away. Many electronics can interfere with each other. Also, is there a fluorescent light in the area? Is there a dimmer switch being used.
You could also go the reverse route and unplug everything from the system except the amp and see if there's hum, then start adding components back in one at a time.
I am missing something here. Is it a hum through the speakers or a hum from the actual transformer?Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm. -
There is a hum originating from the actual amplifier itself when it is powered on.
There is a slight white noise/hiss originating from the tweeters of the speakers when the amplifier is powered on.motorhead43026 wrote: »I am missing something here. Is it a hum through the speakers or a hum from the actual transformer?
Ok, that is what I thought.
I would turn off a circuit breaker one at a time and see if the noise goes away. You could have some DC on one of your circuits which can make a transformer hum.
If you can, might consider getting a dedicated circuit installed. On my to do list for 2018.
I just tested the amp with nothing plugged in on every outlet/circuit in my apartment, same hum.
Then I took it to my office building (built in 1993) and tried on three different outlets in various offices. All three resulted in a hum from the amp.
In the first office the hum was also accompanied by a high pitched electrical noise. On the second outlet it was just a quiet hum, on the third outlet it was a very quiet hum.
Unfortunately none of them resulted in silence.
Conclusion is that it's not my apartment's power that's causing the humming sound.
Thoughts? -
Ask for a refund
While Kerry had a dead silent amp in his posession, the amp always exhibited some very small degree of transformer hum for me. Like Drew, I live in an apartment and the power in this place is far less than ideal. I cannot hear a hum from the listening position or from the speakers but I can feel a vibration from time to time on the amp. @SCompRacer assures me that this is a very common phenomenon and it’s difficult, at best, to determine the source, cause, or resolution.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Is there any McCormack amp owners that state they have a humming amp with hiss coming out of their speakers and are completely happy and complicit about it?
If there are, they bought their amps for peanuts.
I've emailed TMR and I will share their response here.
My conclusion is that if in fact their technician who tested the amplifier before the sale did not hear a hum coming from it, then their listening/testing area was not quiet enough.
If it did in fact not have a hum before it was shipped, then something transpired during the shipping process to cause this hum.Ask for a refund
Maybe I am being unreasonable about the hum, and that it could be "normal" for an amplifier that is 10+ years old. However, my previous experience with power amplifiers is that they don't make this sound when powered on.
I would hate to get into a situation where the amp gets shipped back to TMR and they claim that the noise is "normal", or "quiet enough to be acceptable" etc.
If the item description on TMR's website said that they unit exhibits an audible hum I would have never bought it. -
I agree that the ad should've stated a small hum is audible up close if that was the case. I seriously doubt they'll ever admit it though. But then if they did state that, nobody would buy it without a drastic reduction off MSRP.
They thought it was sold and gone probably.
They themselves might have bought it at a seriously reduced price and then went to pass it on as a fully functioning QUIET amp. I'm just upset when scenarios like these happen.
Forgive me.
TonyMost people just listen to music and watch movies. I EXPERIENCE them.
Drew....your chasing ghosts...
If the amp does a "buzz hum" at start up....no worries.
You have tried to eliminate the result at three points of trying. Without eliminating the first cause.
Amplifiers hum..... Let it be a part of the chain and then ignore it. -
Oh, a few quirks that I forgot to mention in my post.
It makes a thump sound through the speakers when you turn it on, and also slightly dims the lights.
Also, if you put your ear up to the tweeter with no signal, you can hear a very slight hum/buzz.
Also if you kneel down next to the amp itself you can hear a slight hum/buzz, presumably coming from it's power transformer.
The NAD integrated was literally silent, FWIW - from both the speakers and the unit itself.
Not showstoppers by any means since when music is playing you can't hear it. Just figured I'd mention it.
Serious questions here. Not being a smart a$$.
How often to you put your ear up to the tweeter with no signal?
How often do you kneel down next to the amp?
If you can't hear when the music is playing, what's the issue? I suppose just the fact that you know if you put your ear to the tweeter with no signal or knelt down next to the amp you know it wouldn't be silent. I get it, but I'd sure try to get past it if I liked the sound the amp was producing.
Anyway, best of luck on whatever you decide to do. Great looking system you've got.
Things work out best for those who make the best of the way things work out.-John Wooden -
Thanks Paul. BTW.....that amp you sold me is a paperweight.
Going to have to politely disagree with that. I just hooked my NAD integrated up, which is an amplifier, and I get zero hiss from the tweeters and the unit itself is absolutely inaudible. I put my ear 2 inches from it and there is literally no noise coming from it whatsoever.
It's simply not accurate to say "amplifiers hum" as a blanket statement.Amplifiers hum..... Let it be a part of the chain and then ignore it.
I definitely see your point, it's very possible that this is just a quirk of how these amps operate. However, I don't believe it is based on other McCormack owners stating that their amps are silent in operation. The hum can be heard by kneeling next to the unit, yes, but my wife also mentioned she could clearly hear it as well and she was roughly 11 feet away. It's a weird frequency that resonates.
That's the thing, to my ears it didn't sound any different than the NAD. $400 NAD vs. $800 McCormack and the NAD is giving me blacker blacks and better S/N ratio?
Doesn't seem like all is right with this particular DNA-125. Even when I spoke with SMc today they mentioned that the DNA should be giving me a much different/better sound signature.I get it, but I'd sure try to get past it if I liked the sound the amp was producing. -
Full disclosure, I had mine plugged in to a PS Audio Powerplant. -
Oi! @gmcman. !!!
Which is why I suggested a good non current limiting PC. Hum is one of those things that drives me nuts, be it normal or not. I want a dead silent system.
I have a PS Audio PC too, but it's more along the lines of an entry model that I picked up for like 3 bones. Does what it's suppose to do and my system has always been quiet as a church mouse.
I think the OP has a few choices at this point.
Get a power conditioner
Sell the amp and recoup most the coin
Trade the amp for another.
Other adjustments to the incoming power, circuit breakers/wall outlets/dedicated lines aren't possible seeing he's in an apartment.HT SYSTEM-
lsi 9's -
I would make a call over to Josh at TMR. I have worked with him many times and he is 100% focused on customer satisfaction and repeat business.
Make sure he understands your concern(s) and let him help remedy the situation.
Good luck with whatever you decide. That is a great amp and you will be hard pressed to find anything that even comes close for the cost.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
This part I really understand. If I'm paying twice as much for an amp (or anything else for that matter) I expect improvement.
Best paperweight money can buy
Clipdat wrote: »
Indeed it should, which means one of 2 things in my mind. Either your incoming power is that bad, or the amp itself needs some maintenance. Not much you can do about the apartments juice, aside from springing for a good power conditioner. Even then, you may still find the amp needs some maintenance or something got jarred loose during shipping.HT SYSTEM-
lsi 9's -
Thanks for the additional point of contact.
Been emailing with another member of their customer service team, so I will see how that plays out first.I would make a call over to Josh at TMR. I have worked with him many times and he is 100% focused on customer satisfaction and repeat business.
Response from TMR:
"If the amp isn't going to work for you I'm happy to get it back here. If you decide that this is the best option for you and you would like to return the amp I can set up an RA to get the unit back here. Let me know how you would like to proceed and I can get you an RA and address to start that process.
With regards to it having been damaged during shipping, unless the transformer physically came detached during shipping there isn't much else that could cause this that wouldn't immediately cause the fuses to blow. You wouldn't even have time to hear the transformer hum. It would be obvious if the transformer had come detached as it would be bouncing around inside the chassis. With a torrodial transformer there is always some level of transformer hum when it is in operation. This can be increased with DC offset on the AC lines.
Let me know how you would like to proceed and I'll get that started for you."
So I guess now we get to decide who pays for the return shipping.
Also I don't know why he mentions a toroidal transformer, as this amplifier uses an E-I transformer. -
You should hear the transformers hum on my Bryston 4B3, OP would probably throw it in a river.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Re-reading the response from TMR, I don't like the tone of that email at all.
Why is it that it "isn't going to work for you" versus there being something physically wrong with the amplifier? It's being spun around back on me like the issue lies with me, not the amp. -
Did you try turning off each circuit breaker one at a time until the only one left is for the amp?
Nope, but I did unplug everything else that was on the same circuit. And then as mentioned I physically took it to my office building and tried it there. In my opinion, I effectively ruled out the source of power being the culprit.Did you try turning off each circuit breaker one at a time until the only one left is for the amp?
I have to respectfully disagree. Does your office have flourescent lights? If so, likely many of them?
Unplugging an appliance, doesn't remove the possible DC from the live circuits in your home.
The only way to rule out the power source, is to de-energize the other circuits in your home. Everything shares the same ground, and is tied to the neutral buss.
Try what I said and report back.
