Vintage Monitor and SDA Speaker Deals
I am holding a brochure that refers to BOTH the 6 1/2" mid-bass drivers AND the tweeters as "tri-laminate". I used to think it was just the tweeters. Then, recently, I thought it was just the mid-bass drivers. I need to sort my....Bitfrost.Yes it is a tri-laminate tweeter. That is why some are gold, silver or a dark color. I'm guessing it was which vapor deposited coating when on last.
It's the tweeters, not the mid-drivers.
I thought "TL" stood for "tri-laminate" which was the certain combination of polymers on the cone, or something to that effect. Maybe the last non-TL 1.2 had the tri-laminate drivers but didn't have the same array as the TL, which might explain the different crossovers.
It was explained to me the reason for the different colors was they could not control the outcome of the process. Since there are only two metals deposited, the polymer being the 3rd layer, I'm pretty sure the 3 different colors were not the result of which coating was applied last. -
The brochure reads: "Each SRS model features an array of Polk's exclusive Trilaminate Polymer 6 1/2" midbass drivers that exemplify today's state-of-the-art loudspeaker technology."
A few pages later it says: "The Polk SL 3000 Trilaminate Dome Tweeter sets new standards for bandwidth, flatness or response, phase linearity and power handling."
I found a working link: https://polksda.com/pdfs/SRSTLBrochure1990.pdf -
Reefer to my previous video.
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Not the same. The speakers in the eBay ad are 1.2's. The speakers in the Audiogon ad are 1.2TL's.
I goofed. I went from the original 1.2's ebay listing to an ebay link of the audiogon 1.2TL's for ~$4500 and mixed them up.
https://www.ebay.com/itm/Polk-Audio-Reference-SDA-SRS-1-2/322929082983?_trkparms=aid=888007&algo=DISC.MBE&ao=1&asc=49565&meid=fb99ffd9d3374d06967a9c8eef921f3f&pid=100009&rk=1&rkt=1&sd=122855562055&_trksid=p2047675.c100009.m1982 -
Marketing screw up. It's only the tweeters. -
That would explain why the drivers for the last non-TL 1.2's and the TL's are exactly the same. -
There appear to be some SDAs hiding among this Luxman gear...
https://nwct.craigslist.org/ele/d/polk-audio-set/6397176942.html -
That's some very dirty electronics !
500.00 ???? Good luck.Most people just listen to music and watch movies. I EXPERIENCE them.
That's a win!
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
First gen 10s and then tuned!!! I'm down.
saw this add looking at the above add.
Monitor 5's and monitor 4's for 100. Great cond. too !
https://www.ebay.com/itm/Polk-Audio-Vintage-Speakers/263359100506?_trkparms=aid=222007&algo=SIM.MBE&ao=2&asc=41376&meid=66ab9a2d5a114c44b9905231a3d98993&pid=100005&rk=4&rkt=6&sd=162815006020&_trksid=p2047675.c100005.m1851Most people just listen to music and watch movies. I EXPERIENCE them.
Those lead me to these 2B's advertised as 2A's for $230.00.
https://ebay.com/itm/A-Pair-of-Polk-SDA-2A-Speakers-with-SDA-Cable/112695100545?_trkparms=aid%3D888007%26algo%3DDISC.MBE%26ao%3D1%26asc%3D41376%26meid%3D825831c334544fab94d34b6f8da2a06d%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D263359100506&_trksid=p2047675.c100009.m1982"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Found these on CL (SW Michigan) Nice pair of 1C's with new RD0194 tweeters. 600 bucks. 1C's don't come up very often.
https://nmi.craigslist.org/ele/d/polk-sda-1c-speakers/6420141251.htmlBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Looks like Traverse City pretty far north
SDA's for a bill and a half, north of the Golden Gate Bridge. No affiliation. https://sfbay.craigslist.org/nby/ele/d/polk-audio-sda-2-black/6428816189.html
His name is Glenn, super nice guy, I've traded with him a few times. I'm out of room or else I'd jump on em!
my 3.1TLs
I will fix your shifted magnets for free.
I would but I have embarked on my transitional 1C upgrade path. Jumped in the rabbit hole both feet !!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
^^ Not treated very well, but if they're functional - those look to be a good deal ^^VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Maybe a smokers pair. A reduction to 500 or lower maybe. 3 torn drivers, ouch.
Then a trip to Johann's crafts for grill cloth material and a bottle of 409 cleaner from the grocery store.
409 dissolves nicotine almost instantly. I've used it many times on speakers and receivers. Get the scented 409, it makes the messy clean-up smell a bit easier to bare.Most people just listen to music and watch movies. I EXPERIENCE them.
Same City
same tile floor.
same wall color too I believe.
Different seller name though.
Rt11t's for 250.00
Great Cond. !
https://www.ebay.com/itm/Vintage-Polk-audio-11T-Monitor-Series-Floor-Standing-Speakers/182966307020?_trkparms=aid=222007&algo=SIM.MBE&ao=2&asc=44039&meid=967a28b4ebc743c38dfe72001dd2510f&pid=100005&rk=6&rkt=6&sd=282794729792&_trksid=p2047675.c100005.m1851Most people just listen to music and watch movies. I EXPERIENCE them.
Very possible !
They probably sold them to that thrift store for 50.00 or 100.00.
Yea I missed the ripped drivers, etc. Smoked - not smokers pair indeed LOL...VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
https://www.ksl.com/classifieds/listing/50765124
Obviously no affiliation, but if someone was in the area and willing to ship them, my brother in law would be most grateful. -
Original SDA SRS 2's (1986) for $250!!!! And they look MINT. Somebody, ANYBODY, in Wisconsin, please run (don't walk) to pick them up please! I wish I was closer. I have always wanted to add this to the stable (no affiliation)
http://www.usaudiomart.com/details/649352599-polk-sda-srs-2/HTAdcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).2 Channel (Living Room)Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.2 Channel (Office)Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).2 Channel (Garage)Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
