bi-wiring rtiA5
anybody tried to bi-wire your rtia5? how does it perform after bi-wiring? I want to do bi-wire with my Yamaha RX-V2400, it has got speaker A B setup allowes to bi-wire. Any thoughts? Happy new year :)
  • gp4jesus
    gp4jesus Posts: 2,019
    if you have the wire, try it. expect others to chime in w/"don't waste your time."
    *all connected w/Premiere ICs
    F1nut Posts: 52,151
    Simply replace the stock jumper plates with high quality speaker cable.
  • PixOtt
    PixOtt Posts: 15
    16 gauge and any recommended brands? thanks
    F1nut Posts: 52,151
    edited January 2018
    If you are stuck on gauge, it's not high quality speaker cable. However, it would be better than the stock plates.
  • gp4jesus
    PixOtt wrote: »
    start w/whatever you have though I'd go heavier than that between the amp/AVR and speakers.
    my $0.01
    PS: welcome to Club Polk if you haven't receive that
    Tony
  • soundfreak1
    soundfreak1 Posts: 3,414
    This is the "don't waset you time" that gp4 mentioned.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • I use 14 gauge quad cable from blue jeans and am fine with it. Personally, I would spend my money on other things.....The biggest difference that I’ve noticed in my setup is the crossover mod on my RTi8’s. I used Sonicap caps and Mills resistors.
