Sunfire TGP 5 display issue
Hey guys,
I have a Sunfire TGP 5 that I purchased new a few years ago. It has been great with no issues.
The display is very dim for some reason, and I thought someone here may have ideas of how to fix the issue??
The dimmer works and I have cycled through all settings with it and on the brightest I still can't see it unless I walk up very close to it.
Is there LED's or something that can be replaced fairly easy??
Thanks for ideas.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
    treitz3 Posts: 20,122
    Sounds like it would be a simple fix but if not, the boys over here will steer you in the right direction. They are always modding/repairing gear.
    http://thecarversite.com/yetanotherforum/default.aspx?g=forum
    nooshinjohn Posts: 26,002
    Good advice Tom
  • vmaxer
    vmaxer Posts: 5,121
    treitz3 wrote: »
    I went over and signed up and posted the same thing.
    Pretty sure I had signed up there before but couldn't remember login info/
    Hopefully someone will know how to address this issue.
    Thanks a lot.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,121
    Well so far not any replies at all over there??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Give it some time... it is still the holiday season... Bill Flannery would be another guy to reach out to.
    http://www.flannerysvintageaudio.com/
