Steelers got robbed
gmcman
The ball never touched the ground, they got hosed.Political Correctness'.........defined
President of Club Polk -
Here come the Squealers
– Kevin Alfred Strom -
You have to control the ball all the way to the ground.
He didn't.
Yeah, unless you are a RB, then you can reach across and lose the ball and it's a TD. How is that okay, but the catch he made wasn't? I know that's the rule, but it's dumb, he obviously caught the ball and had control as it crossed the plane. -
It's the "dez rule"....stoopid but it is what it is2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »It's the "dez rule"....stoopid but it is what it is
Correction, it's the Calvin Johnson rule.
What was in the news more...tit4tat...whatever2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
By the other rules, ball crossed the plain, he had control of the ball. In my view, the play was dead as soon as his knee hit the ground while in complete control of the ball.HT SYSTEM-
lsi 9's -
Tom Brady go away and let somebody else play.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
I agree with you that in these situations it should stand.
But, the current rule does not agree with us. If the receiver loses control of the ball while coming down, it’s not a catch.
As the rule is now, it was the right call. -
His right hand had control of the ball the entire time. They got hosed and I really don't like the Steelers.Political Correctness'.........defined
I am still pi$$ed @ the Steelers for the "The Immaculate Reception"
Serves them right.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
motorhead43026 wrote: »I am still pi$$ed @ the Steelers for the "The Immaculate Reception"
Serves them right.
That happened so fast the cams didn't even catch it2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
But he didn't lose control, he had it even after his knee hit the ground. If your going to say the ball is still live after he hit the ground, then the ball crossed the plain while in his control. How long after he hits the ground does he have to maintain control ? Because he hit the ground before crossing the plain with complete control. The very least....it was a catch at about a foot short.HT SYSTEM-
lsi 9's -
He is not down till he’s touched. The receiver has to control the ball all the way to the ground. He lost control when his elbow hit the ground. Had he made two steps prior to losing control then he would have been a runner with possession of the ball and would have only needed to cross the plane. But he wasn’t cause he didn’t and consequently dropped the football making it an incomplete pass.
They got the call right.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
Long story short, if New England would have touched him when his knee hit the ground, before reaching over the goal line, the ball would have been placed on the 1' line....like I said...stoopid rule2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
He has to make a "football move", which is an insanely ambiguous term.
Usually it would mean planting your feet and moving while controlling the ball.
What he did was all under the umbrella of "coming down with the ball". If you bobble the ball and it contacts the ground AT ALL, it's a no catch.
That ball clearly had contact with the ground.
Yes, he had control of the ball when he stretched out, but it's a moot point here. It's not a completed catch since he lost control while coming down. You can't rule a play a TD with an incomplete pass...
The concept of the "the running back can lose control after it passes the line" does not count here. A RB's possession and a receivers possession fall under totally different rules. The RB's rule would have applied IF he was considered a runner (completed the catch and running with the ball), he was not.
He was a receiver that failed to maintain control while coming down with the ball. -
Gotcha, if your a running back, you can be the clumsiest MF on the planet, but a receiver has to catch the ball, do 2 forward flips, a back flip and plant his body 4 inches into the dirt before its a catch.
Good point Skip on the football move.HT SYSTEM-
lsi 9's -
He caught the ball, his knee was down, he wasn't touched and basically carried the ball into the end zone. It is not the same as catching the ball in the end zone. It was a touchdown.Political Correctness'.........defined
Again, I agree that it should stand.
But the rules don't. Everything he did was "in the act of going to the ground" and in the end, he did not maintain control all the way down.
I don't agree with it, but the rules are what they are. -
But he would have been down if the D would have touched him when his knee hit the ground prior to him reaching over the goal line2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »But he would have been down if the D would have touched him when his knee hit the ground prior to him reaching over the goal line
If he maintained possession of the ball...
His stretch and attempt to get the TD cost him control and it cost him the catch. -
Upstatemax wrote: »txcoastal1 wrote: »But he would have been down if the D would have touched him when his knee hit the ground prior to him reaching over the goal line
But at that point, he is no longer a receiver since he's already on the ground. Then, all he needs to do is cross the plain, control after that is irrelevant. No ?HT SYSTEM-
lsi 9's -
Simply, no.
His pivot and stretch were all part of him going to the ground with the ball.
When making a catch like that, until he is fully on the ground with clear possession, it’s not a catch.
This same rule has burned, and benefited every team in the NFL. -
Nothing y'all say matters. Game Over.
txcoastal1 wrote: »motorhead43026 wrote: »I am still pi$$ed @ the Steelers for the "The Immaculate Reception"
Serves them right.
Should have been an Incomplete Pass IMO, Old, old news anyway.Carry on.
And in other news... Teddy Bridgewater found his way back under center for the first time since nearly loosing his leg in a gruesome non-contact knee injury.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Being an unfortunate Browns fan, I just like reading the title of this thread and watching it stay at the top of the recent discussions.
Bump.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
If you watch the replay of the Steelers catch, he caught the ball and held it steady with both feet in the air, then both feet touched along with his knee. At that point it was a controlled catch imo.... then he reached for the plane, and crossed it. I understand about control to the ground, but he already did that.
This is one of those rules that grants far too much power to the officials. It isn't clear cut and allows them to alter the outcome of a game.
That being said, the Steelers still had the opportunity to AT LEAST take the game into overtime. Throwing into traffic like that was a flashback to the Patriots/Seahawks Superbowl.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects -
^^Agree, so they didn't deserve the win anyway.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
