Speaker Stand Suggestions for LSiM 703
13»
Answers
  • Hermitism
    Hermitism Posts: 4,329
    Thanks. I was going to use empty toilet paper rolls and tape after seeing what I've got to deal with. And a funnel. Shot comes Monday, so I need to get to poopin'!
    F1nut Posts: 51,763
    Yep, a funnel helps too.
    msg Posts: 10,452
    Couple of Pics.. pretty darn pleased with these.
    Nice job, Ray - your setup's looking great. Very clean.
    You'll have to post up sometime to let us know how the 703s and S60s compare.
  • rburgess714
    rburgess714 Posts: 618
    edited December 2017
    msg wrote: »
    Thank you Scott. I am pretty happy with it. I will at some point write a comparison between the 703s and 60s, I have been waiting for them to “break-in. So far very impressed with the low end and experimenting with placement.
    Post edited by rburgess714 on
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
    msg Posts: 10,452
    Hermitism wrote: »
    Another Saturday night with Richard Gere, uh?
  • Mikey081057
    Mikey081057 Posts: 7,127
    These work great for less than $15
    Garage | Polk Monitor 5B's
  • Hermitism
    msg wrote: »
    Hermitism wrote: »
  • mrloren
    mrloren Posts: 2,474
    Oh my keep it clean.
  • saturn1
    saturn1 Posts: 30
    I bought the TransDeco speaker stands for the 703s. For now, I am using the little rubber isolation pads for the placement of the speaker on the top plate, but later I might add some blue tack to secure it a little better. I would like to add further weight to the base, but preserve the wire management capabilities of the stand. Has anyone ever tried using polymeric sand to fill the posts. It should harden and dry out after a while. I was thinking of inserting a small diameter conduit (e.g. PVC pipe) that exits the top and bottom holes and pouring polymeric sand around it.
    Bad idea?
