Vintage Monitor and SDA Speaker Deals
Either crackhead pricing or someone's partaking said crack
What's the difference between a crackhead and a partaker of crack?
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
A crackhead will take $20 for a pristine set of SDA's, whereas someone smoking crack wants $2000 for an abused set.Don't take experimental gene therapies from known eugenicists.
The crack pipe was passed around the circle but he was not a partaker so he waved it away. He could have partook but declined to partake because if he'd partaken he'd be a crackhead.
Yes!!! The 2 bottom central pair are (appear to be) upper end Sony APM, especially the black pair (port configuration is different between the mid and upper end series).
Why do you ask?
I'd be all about the APM AV-930s (black pair). The others are the little brothers to the 690s I have in my avatar.
http://pages.ebay.com/link/?nav=item.view&id=263324234413&alt=web
No affiliation, but seems like a reasonable price.
http://pages.ebay.com/link/?nav=item.view&id=132421905866&alt=web
Cheap??? Just far away. -
So is the auction for rt25's or srs?
Curious as I'm 30 minutes away.
One of each, maybe?
That's one mucked up listing
DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
From what I gather, it's the SRS since that's the items pictured. The description is a stock copy of Polks literature. -
To add further confusion, the positive binding post nuts are on the left but the sticker says they are supposed to be on the right.
The most important thing to find out is what type of interconnect socket it has. If it's pin blade then they are 1.2's and the binding post nuts are in the correct position regardless of what the sticker says because Polk is notorious for using old stock on newer models. If the socket is blade blade than they are first generation srs's and the positive binding post nuts should be swapped over to the right side.
If someone here on the Forum ends up buying them, remove the four screws on The Binding post cup to make sure everything is correct.SDA SRS 2.3TL's
SDA 2B TL's -
Price has been edited... Now states $999.00 opening bid. Hmmm
The cabinets don't look original to me. Home made or from a different speaker?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Not sure if these have been posted:
https://portland.craigslist.org/mlt/ele/d/polk-audio-sds-srs-23-speakers/6420522933.html2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
[/quote] I contacted the seller, he states that the interconnect is pin/pin. What?[/quote]
There's no such thing as a pin/pin socket LOL. Ask him if there's a round hole and a rectangular slot or 2 rectangular slots.
SDA SRS 2.3TL's
SDA 2B TL's -
I can clearly see the cable is pin/blade in the images.
The_Polkster wrote: »I can clearly see the cable is pin/blade in the images.
Are you referring to photo #4 in the Ebay ad? If so, the cable is plugged in so it's impossible to tell what type of connection it is.SDA SRS 2.3TL's
SDA 2B TL's -
Image 4, upper left corner, in the baggie. Unless my eyes deceive me this is a pin/blade. -
Is that photo from the eBay ad? It's definitely a pin blade cable.SDA SRS 2.3TL's
SDA 2B TL's -
What's up with these odd birds out in the Valley of the Sun?
https://tucson.craigslist.org/spo/d/3-vintage-polk-audio-speakers/6419065375.html
The layout says 5jr+, but the tweets are wrong, and the offset is very odd. But hell, at $60 for 3 of them, I'd say it's worth the gamble. You could always part them if the boxes are bogus. -
The_Polkster wrote: »Image 4, upper left corner, in the baggie. Unless my eyes deceive me this is a pin/blade.
They are talking about a different listing.
Although I would like to be the first to point out that the baggie includes an AI-1 cable.
That is AI-1 interconnect much better cable than regular p/b interconnect. It add at least 100.00 to the set
There was never anything other than pin/blades in the 2.3 series -
SDA 1b pair needing TLC. Asking $400 OBO. No affiliation.
https://atlanta.craigslist.org/nat/ele/d/polk-audio-sda-1b-speakers/6404430325.htmlExpect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
Polk LSi7's - https://www.shopgoodwill.com/Item/46577965VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Keeping an eye on that one... -
/\/\/\These were for sale May/June this summer on craigs list. Same photos,same description, same price from Binghamton NY. I passed. Its too much of a college town. Didnt want to take a chance that these were bounced around frat houses over the years. But you never know.Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
You and me both brother lol... and another couple things I found there too"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
https://lincoln.craigslist.org/ele/d/polk-audio-sda-ii-speakers/6374933267.html
https://newjersey.craigslist.org/ele/d/polk-audio-sda-2-stereo/6398451218.html
https://richmond.craigslist.org/ele/d/polk-sda-2a-speakers/6419276853.html
https://chicago.craigslist.org/sox/ele/d/polk-audio-sda-2/6419592404.html
@kharp1 https://louisville.craigslist.org/ele/d/polk-audio-sda-1c-speakers/6415530230.html
And I saved THE BEST for last... They can be yours for the LOW LOW LOW price of 1400
Polk SDA-1A's
