Legacy Focus 20/20 and Butler 2250 amp
1235»
    Viking64 Posts: 7,709
    tonyb wrote: »
    ...even if you can only do one piece at a time.
    https://www.youtube.com/watch?v=rWHniL8MyMM
  • vmoreno74
    tratliff wrote: »
    vmoreno74, although the AS2100 is a great integrated I am thinking the speakers could use additional current as Tony pointed out. You will be pleasantly surprised how those speakers will come alive when big power is supplied.
    I tried a couple of different setups with my speakers and finally settled in when I brought in the 600 watt mono blocks. Don't let the efficiency of the speaker steer you away from current. These speakers can gobble up power when provided.
    PM me if you want to discuss details.
    Just wondering how much the sound would open with your recommendation as I already feel the sound is great!!! Did not want to, but seems that I have to go back to the rabbit hole! LOL
    vmoreno74 wrote: »
    tratliff wrote: »
    You can never have too much power, but like I said, something north of 40 ampere's peak to peak should work well. The more the merrier.
    Rabbit holes are common in audio, one upgrade begets another until your wallet runs dry or the wife threatens to leave you while the dog is stuck eating gravy train from Walmart.
    Like I tell most folks, one piece of the puzzle at a time when the wallet allows. We have a few Legacy owners here and we can guide you to what works well with them, narrow things down some. Otherwise your chasing your tail, too much trial and error and wasted money. Nobody likes wasted money.
  • Nightfall
    Nightfall Posts: 10,083
    That Yamaha is like a $3,500 integrated. 52 pounds. Basically doubles down from 8 to 4 ohms. You guys really think it's the weak link?
    afterburnt wrote: »
    Village Idiot of Club Polk
    Nightfall wrote: »
    Yes, it's still only 150 watts at 4 ohms. I was pushing 450, with around 70 ampere's peak to peak of current and it gobbled them up no problem. Takes a lot of current to manhandle 6 12 in. woofers between the pair. Well really 4, 2 are passive.
    Will they play on a 150 watter ? Of course they will, but in my opinion not at their best.
    A better example of an integrated with current/balls to it, would be Musical Fidelity's. Certainly others would work also. You just need something with more balls to it is all.
  • Nightfall
    I can't find the specs on the current of the Yammies. Something is up with them though, they have to be packing some balls behind those watts because even the $7-8,000 AS3000 is 150 at 4 ohms.
    afterburnt wrote: »
    or....add an amp to the Yammie. McCormack amps would work well and sound great. Belles, and the Butler I thought was a great match.
  • Nightfall
    tonyb wrote: »
    Nice find, looks like it just came out of the box.
    afterburnt wrote: »
    I'd buy that sucker myself if I had a few more coins. The Yammie is a fine integrated, nobody is questioning that, and if he thinks it sounds good to him then why change a thing ?
    I know, since they were my speakers, that more power would benefit them. That's all I'm sayin'.
    In my opinion, the problem with an integrated is, your locked into the amp and pre sections. Sure you can add one or the other to it, but then your questioning why you have an integrated to begin with once you start down that road.
    pitdogg2 Posts: 27,572
    edited December 2017
    tonyb wrote: »
    Is that amp really 150 amps current peak to peak? That seems excessive.
    tonyb wrote: »
    It is, typo probably....should be around 70-ish. Still, for the 5 bones it's a steal for those on a budget.
  • teekay0007
    teekay0007 Posts: 2,288
    tonyb wrote: »
    You guys are aware that the amp pictured and for sale there is a Mono (one channel) amp, no? He has it mislabeled as Stereo. Look at the Owner's Manual - "EX4420M Single Channel Amplifier" and the pictures ("Mono Power Amplifier" printed on the front of the unit). The two sets of binding posts on the back are wired in parallel and give the same channel output.
    I have a pair of the B&K Reference 4420M (Awesome!) amplifiers, configured the same way. My manual also says 150 Amps peak-to-peak! B)
    tonyb wrote: »
    tonyb wrote: »
    Well yes it is a steal at that price. In my looking at different amps I've never seen any that high including large monobloc's
    teekay0007 wrote: »
    tonyb wrote: »
    Well ok then i stand corrected that is serious current. You could jump start a car with that.
    Missed the M after the designation too. Dang, getting old sucks.
    tonyb wrote: »
    You just missed a few more M's. That should read: "Mang, getting mold sucks." :p
    Well then that would make a heck of a center channel amp :D
    There's a McCormack dna-1 in Chicago for 750, good match for the Focus speakers. It's on Audiogon.
  • daddyjt
    daddyjt Posts: 3,190
    I'll second what Tony is saying - the Legacies will play on lower power, but they really come to life with A LOT of power. I'm very happy with mine running the McCormack DNA 225.
    ― Aleksandr Solzhenitsyn
  • vmoreno74
    Took some time to digest all the comments as it is indeed a lot of info.
    I am guessing you guys have your system in your basement, right?
    I also out of curiosity played a concert last night to check on the power of the amp and my wife came down to ask me to lower the volume as she was feeling the vibration while she was reading to our son (even though I installed SVS soundpaths to the speakers) So I was wondering what 400 watts of power could do to the house? :o
    I think in order to have the tube sound and considering that my amp is an integrated I will test "tube DACs" within my budget and decide for the one that sounds the best.
    On a separate note, I am happy that I found this community, you guys are awesome! Thank you so much for your suggestions and recommendations.
    Special thanks to Tonyb, man thank you for letting me take care of your babies, they are indeed sweet and revealing, all the hype about these speakers is true!
    EndersShadow Posts: 17,741
    If you want tube sound to play with.... look at tube buffers. Easier to play with as you can add or remove them from the path of your current gear easier.
  • kevhed72
    kevhed72 Posts: 5,189
    edit
    Post edited by kevhed72 on
