This joint needs some more vintage hifi
1484951535456
  • sucks2bemesucks2beme Posts: 4,826
    The AU-999 is a warm sounding amp. Go to audiokarma and look up
    the rebuilding and troubleshooting info. The au-999 improves greatly with a few changes on the preamp board. Good news, almost all the electronics are on removable
    circuit boards. Easiest amp to service I ever owned. It's not at the same level as the au-717, but with the modifications it gets much closer to the same sound.
    And that Mac 1700 is well worth a rebuild.
  • WardswebWardsweb Posts: 791
    JBL C50 with custom 2397 horn and JBL L100
    Living room:Maplenoll turntable, Clearaudio Champion II turntable, Sonic Euphoria pre, EAR 834P phono pre, Shanling CD-T1500 sacd, Auralic Altair DAC/server, PS Audio Quintessence power, ASL AQ1006 845 DT MKII mono block amplifers, DIY Altec/JBL speakers
    Sun room: Roksan Radius 5 turntable, Lounge phono pre, DIY Class A 6H30 linestage, DIY 2A3 amp, Krell CDP, JBL C50 Olympus speakers with custom Smith horns, Klipsch Cornwall III
    Den: Onkyo TX-NR929 receiver, Oppo BDP-103 player, Panamax M5400-PM power, SST Ampzilla 2000 mono blocks, Behringer EP 4000 sub amp, Electrovoice DX-38 active, Klipsch Jubilee speakers, Martin Logan Cinema center, JBL SAT2 surrounds, Danley DTS-10 sub
  • mhardy6647mhardy6647 Posts: 20,039
    What driver on that horn, Mr. W?
    I've probably seen it before, but I don't recall.
    In recent months, I've become somewhat more interested in certain bits of JBL hardware.
    Mid driver is a JBL LE85. Tweeter is a JBL 2405.
  • oldrockeroldrocker Posts: 2,020
    LOVE those vintage Ads.
    5 bucks down.
    6 bucks a month.
    If I only had a time machine.. B)
    I am oft tempted to fill in an order blank in an old Allied catalog and send it in...
    source: www.alliedcatalogs.com (1961)
  • jdjohnjdjohn Posts: 523
    sucks2beme wrote: »
    The AU-999 is a warm sounding amp. Go to audiokarma and look up the rebuilding and troubleshooting info. The au-999 improves greatly with a few changes on the preamp board. Good news, almost all the electronics are on removable circuit boards. Easiest amp to service I ever owned. It's not at the same level as the au-717, but with the modifications it gets much closer to the same sound.
    I've been reading about the mods for the AU-999...will definitely be considering those as I do a recap. I got the other channel to work...was missing a fuse. The AU-999 has a fuse for each channel output, and one was missing, AND the fuse cap was the wrong type (wouldn't even screw in) :s I got a replacement fuse cap off eBay, new fuses from The Home Depot, and back in business! Sounds pretty good as-is, but looking forward to doing the upgrades.
    Yes, definitely going to get the Mac-1700 up-to-snuff. I'll have to farm that work out since I don't have all the proper equipment for the (quite involved) FM/MPX calibration. There's a guy down the road in Knoxville who specializes in vintage Mac gear - audio, not Apple :D
  • ConradiclesConradicles Posts: 5,767
    This one might be mine:
  • soundfreak1soundfreak1 Posts: 2,826
    There's one of those on CL in safety harbor fla. For 210.00. Just saying. No affiliation.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • FestYboyFestYboy Posts: 3,137
    Got to see an 8000 series one of those today. It was massive!
  • Tony MTony M Posts: 6,867
    edited November 2017
  • Back to P-Man's travels to Conn. This guy will travel almost an infinite amount of miles for a set of speakers or a piece of gear he covets. He's one dedicated dude who knows what he wants and goes gets it. Cudos to Bill.
    Tony M wrote: »
    Yes! The owner has it running a pair of 12Bs and says he can't turn it up past 8 o'clock on the volume knob without disturbing the neighbors in the apartment. It's pretty and I want it, but dear God does it take up alot of room on the rack!
    Maybe I'm too tough but I won't deal with any e on the bay with less than a 100% rating.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • pitdogg2pitdogg2 Posts: 12,118
    Even that don't mean much anymore in the era of negative feedback removal.
    People leave negative feedback even if everything is perfect, but their cooch is itchy that day.... Blows my mind the things that people will gripe about just because...
    Does that thing dim the lights in the room when you fire it up?
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Viking64Viking64 Posts: 3,682
    The lights all go out completely and you just sit there in a blue glow. :p
  • Does that thing dim the lights in the room when you fire it up?
    I have another one just like it for the other 1.2tl. They don't dim the lights because they each have their own dedicated circuit
    Viking64 wrote: »
    I actually do that quite quite often.... like almost every day during the winter months :)
    I hope to do the same some day. :)
    I'd love to have a matched pair of 2500's. Nice sound.wouldn't want to lift them up though
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • I'd love to have a matched pair of 2500's. Nice sound.wouldn't want to lift them up though
    Yes moving them is a huge pita and the back to at 129lbs each. The thing that still impresses me is those 1.2s are able to soak up every single last watt to the clipping lights without the slightest sign of distress from those bridged 2500's.
    That's got to be one of the BIGGEST McIntosh Amps I've ever seen ! :o
    Congrats on owning 2 of them ! B)
  • Thanks; I ran one 2500 for a couple years and I was very very happy pairing it with the 1.2s. But once I added the dreadnaught a while back I went on the hunt for a 2nd one. I can't see ever moving on from them as the newer big Mac monos are above my pay grade :'(
    Had to help my buddy (my tech) put one of those on his bench once......damn need blew a nut!
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    Thanksgiving holiday with my parents, and more receivers/amps coming my way from my dad's garage.
    Sony TA-1150 integrated amp...it's blowing fuses.
    Marantz SR6000 receiver...needs a lamp kit, but has a beautiful wooden cabinet
    Marantz 4270 receiver...this thing is a beast...some stencil worn off, and looks like a previous owner was a Dual fan :)
    @jdjohn you selling any of these classic pieces?
  • txcoastal1txcoastal1 Posts: 10,167
    Damn bloodhound :p ;)
    My dad always said "if you don't ask, you don't get" LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
Howdy, Stranger!
