Better Sub or Better Amp?
Kingkwas
Kingkwas Posts: 92
edited November 2017 in Music & Movies
Which one will have a greater effect on my HT setup? A new sub? Or new Amp? Probably need both.
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
  • FestYboy
    FestYboy Posts: 3,861
    Depends on what you have now.
  • rpf65
    rpf65 Posts: 2,127
    Get rid of the bi-wire, get good cables and jumpers, add a 2-channel amp.
    I think you're doing more injustice to the 703's by under powering them than whichever movies you watching low end bass.
  • FestYboy
    Am I missing something? On the mobile app and not seeing a signature. From the above post, I'll assume the 703s are bi-amped on an AVR, and in that case, I'll agree with @rpf65 : use the pre outs and 2 channel your mains with MOAR PaWR!
  • rooftop59
    rooftop59 Posts: 7,973
    No sigs in the mobile app!!!
    Game Room 5.1.4:
    Bedroom 2.1
  • FestYboy
    rooftop59 wrote: »
    Didn't think so.... Oh well...
  • hochpt21
    hochpt21 Posts: 5,423
    I would say a better sub.
    An amp would help, but it's not like he's trying to drive some A9's with an AVR or something...
  • Thorton
    Thorton Posts: 1,324
    hochpt21 wrote: »
    I agree. For HT and using the 703's, I'd go for the better sub/prefer subs first.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • DidierAubin87
    A better sub, as my experiences :# . It also depends on your needs.
  • obieone
    obieone Posts: 5,077
    Better subs; You already have the AVR with 7.2, might as well utilize them with subs with more testosterone.
    Hsu or SVS are good starting points.
    Hsu: http://www.hsuresearch.com/subwoofers.html
    SVS: https://www.svsound.com/
