Better Sub or Better Amp?
Kingkwas
Which one will have a greater effect on my HT setup? A new sub? Or new Amp? Probably need both.
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
R: Def Tech
DVD: Oppo UDP 203
Depends on what you have now.
Get rid of the bi-wire, get good cables and jumpers, add a 2-channel amp.
I think you're doing more injustice to the 703's by under powering them than whichever movies you watching low end bass. -
Am I missing something? On the mobile app and not seeing a signature. From the above post, I'll assume the 703s are bi-amped on an AVR, and in that case, I'll agree with @rpf65 : use the pre outs and 2 channel your mains with MOAR PaWR!
No sigs in the mobile app!!!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I would say a better sub.
An amp would help, but it's not like he's trying to drive some A9's with an AVR or something...2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
I agree. For HT and using the 703's, I'd go for the better sub/prefer subs first._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
A better sub, as my experiences
. It also depends on your needs. -
Better subs; You already have the AVR with 7.2, might as well utilize them with subs with more testosterone.
Hsu or SVS are good starting points.
Hsu: http://www.hsuresearch.com/subwoofers.html
SVS: https://www.svsound.com/
