Repair or replace RTA12s
I have a pair of RTA12 that I've had since around 1979. Thought tweeter had blown. They're the top hat drivers, so I switched them, changed fuse, still only mids and bass, no tweetage. Replaced tweeter with new one from ebay. No tweetage. Question is whether to repair, by DHS Speaker Service, which I favor or buy a pair of Polk Audio LSiM 707. Equipment is Hafler 220 and 100 pre-amp, Rega Planar II w/ Orotofon blue and Yamaha CD-C600BL 5-Disc CD? Please share you views. I'm in Hawaii so cannot demo the LSiM 707s here.
Verify the poly switch is open before condemning the tweet.
Silly boy he states he changed the fuse therefore there is no polyswitch
I'd also clean the fuse holder very well and verify that the wiring to the fuse block had not corroded so much that it can't pass a signal. It's been known to happen -
Repair is my vote.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
Missed that! My bad. That's what happens when you skim...
But I'm with Cody, fix 'em -
Fix them.
Blown resistor?HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5 -
Easy Runnin wrote: »Blown resistor?
Very well could be, but I think that would be very visible. OP take a picture and post it. We might be able to spot something.
Will do this tomorrow. Thanks! -
Well, I went over the mechanical issues one more time. Visually, nothing looked out of place, but I wasn't sure the solder had flowed on the tweeter hot lead. Resoldered tweeter wires with hot iron and good flow. Cleaned fuse and fuse holder with wire brush; sprayed with a dab of CRC. Resoldered fuse holder wires as they looked a bit corroded. Held breath, crossed fingers and plugged in. Put on second Traffic album. Kabaaam! Tweetage restored. Pays to go slowly and carefully. I think it was most likely the hot wire to the tweeter which was on but looked like a cold joint. Have to say, Dave at DHS was very helpful and, when I only have one tuition to pay, I may have him upgrade them with new caps and resistors. For now, it's 1979 all over again, baby! Thanks for all the responses. I truly appreciate them.
That's great to hear. I would of crimped gold plated faston to the wires instead of soldering to the tweeter. Just my personal preference.
Great job tracking it down -
Would have been a good solution if I had the faston connectors, but did not think of it beforehand. Thanks.
