Building a subwoofer
boatlover 5254
yes...
UNless the design dosnt call for it
But in your case, yes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
and wat about the tube thing
Do you mean the port tube?
Have you designed this subwoofer using any kind of computer modeling software, or are you just building a square box and placing a driver in it? The reason I ask is, determining the correct diameter & length of the port tube is critical to the performance of the subwoofer.Bob Mayo, on the keyboards. Bob Mayo. -
I have an inside dementions of 11 1/4inches what size do I need
I would say your best course of action would be to post any information you have on this driver and let the members here take a crack at desinging the box for you.Make it Funky!
I have a 20w woofer
a 25w amp
woofer is 8 indurence
power sub
particlewood box
11 1/4inch square for the inside dementions. -
if you can tell me the model # of the sub & the manufacturer name, i'll run the sub thru WinISD, and design you a quick box.
you don't seem to understand how complicated building a correct enclosure for a subwoofer is. do you know the Theile/Small parameters? this info is required to design the enclosure correctly.
If you don't know any info about the sub, just tell us the brand & model names, and i'll dig up the info for you.Bob Mayo, on the keyboards. Bob Mayo. -
it is a very old woofer. What would you just think would be the right size... This is for science project but i want it to be as good as it can.
If you don't know any info about the woofer, or can't look it up, just forget about the port. Without the necessary info, it is impossible to even fathom a guess at what the correct diameter & length for a port tube would be.
Just leave the tube out, and go with a sealed box design.
Just another thought, do you have an old enclosure that the woofer came out of? If you do, just duplicate the design of the old box.Bob Mayo, on the keyboards. Bob Mayo. -
If i were you, i too would put it in a sealed box enclosure. If i didn't have one available i would just check out the the thrift stores for speakers that you could put yours into, plug the holes, throw in an old pillow on the backside and let it rip.Make it Funky!
the woofer is in a seald box will it effect the sojnd at all with no vent?
Do a search man, Sealed and Vented loudspeaker designs...
Science Project = RESEARCH- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Alright.. Now I knowI'm druckDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
