Anyone know anything about Powerstroke engines?
  • mikeyb128
    mikeyb128 Posts: 2,885
    exalted512 wrote: »
    nbrowser wrote: »
    nbrowser wrote: »
    Jstas wrote: »
    Those are the most common causes.
    I just hope you don't have like a leak in the turbo or a head gasket or something.
    The EGR cooler is always a possibility too...
    exalted512 wrote: »
    It's the EGR cooler that's leaking internally. Which is weird because I haven't seen any white smoke coming out the exhaust. Well, I wasn't planning on deleting this truck, but I'm not going to pay to put that crap back on.
    -Cody
    Apologies for being clairvoyant...Seems to be a bit of a common issue....just delete it if they'll do it...also see about getting the DPF deleted as well...might need a third party shop for that.
    Big shout out to the government for mandating the installation of these.
    Its not like it's a group 1 carcinogen or anything, right up there next to asbestos. :lol:
    2 channel:
    Theater:
    txcoastal1 Posts: 13,512
    Definitely insightful conversation here, as I drive a GMC with a Duramax.
    Found an interesting article and and reviews on kits
    http://www.trucktrend.com/how-to/engine/1709-how-to-repair-cummins-5-9l-vacuum-pump-oil-leak/
    https://dieselpowerup.com/duramax-lml-dpf-delete-kit/
    exalted, please keep us updated...Thanks
  • exalted512
    exalted512 Posts: 10,735
    One of the other problems that I inherited is a leaking injector onto the top of the engine. It had an oil leak that was recently fixed by the previous owner, but the shop didn't clean up the oil so I was looking at a pretty dirty engine anyway, but I digress...this was on me as it was obvious and I don't think the previous owner knew about it either.
    The dealer gave me these part numbers when they were looking at the coolant:
    BC3Z 9229 a
    http://www.ebay.com/itm/NEW-FORD-MOTORCRAFT-OEM-PART-FUEL-SUPPLY-TUBE-KIT-CM5191-6-7L-DIESEL-SUPERDUTY-/281908372720?epid=671908707&hash=item41a30c64f0:g:72EAAOxy9eVRTMMd&vxp=mtr
    BC3Z 9229 b
    http://www.ebay.com/itm/OEM-FORD-6-7L-FUEL-INJECTOR-TUBE-AN-SEAL-KIT-B-BC3Z-9229-B-/112589734723?epid=1670857285&hash=item1a36df0343:g:po0AAOSwC6dZrbWY&vxp=mtr
    I tried looking on youtube, but didn't see any videos about changing these parts out.
    I'm not a mechanic, but I do pretty good with working on stuff. Is there any reason why this is something I wouldn't be able to tackle myself? I'm assuming no special tools or computer programming is needed? Also - what is the difference between the parts? There's only one line going to the injector.
    I have heard that the injection lines are recommended to be replaced any time they are loosened or removed, maybe one has to be removed to get to the other so they want to replace both?
    Thanks!
    Cody
  • motorhead43026
    motorhead43026 Posts: 4,009
    edited October 2017
    This is why we call them FURDS ;)
    – Kevin Alfred Strom
  • exalted512
    mikeyb128 wrote: »
    Which is exactly why I'm getting rid of it so my truck doesn't have to breathe it.
    txcoastal1 wrote: »
    Took it to a shop in Conroe last night. $1950 out the door to delete the EGR cooler. It'll still have the piss tank, though. Maybe a job for another time. I'm going to have to do some more research tonight to see if I want to tackle the injector leak and the vacuum pump myself or just have them do it while it's in the shop. It'll be about the first time I've ever paid someone to work on a vehicle for me that I could likely do myself, but I'm so crunched for time right now I might have to bite the bullet.
    -Cody
  • exalted512
    nbrowser wrote: »
    Just an honest bit of advice...let them do the injector...honestly...it requires a special tool to extract them.
    But there's about 15 different ways on youtube showing different ways to remove them without the special tool. I'm also not sure the injector has to be removed. Hopefully some more research will yield better answers.
    -Cody
  • I always check YouTube University and decide if it’s something I can do myself. Unless there is substantial risk to life or property damage I would give it a try if I were in your shoes.
    audioluvr Posts: 5,914
    Uh...
    exalted512 wrote: »
    Don't bring that kind of negativity in my thread. I only want responses of "oh, that's an easy fix"
    Oh that's an easy fix! Yank out that powerjoke and replace it with a Cummins! Fummins' are cool!
