Any ideas of what to do
kevhed72
With all these super crusty 78s....they all look retro cool but are brittle and dirty as heck....
I see a trip to the dump in your future.Political Correctness'.........defined
President of Club Polk -
Avoid any alcohol based cleaners as the damage the Shellac.
Audio Intelligent vinyl solutions has a cleaner called "Premium Archivist which is safe for 78's available from music direct...
do some web searches for hints & as most say it is safe to use a little water and mild detergent.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
It's been a bit since I've had vinyl, so I might be wrong (as if !) but I tend to think that vinyl and concrete don't mix in the most desirable fashion.
So I'd recommend the following:
Step 1: Remove albums from driveway
Step 2: ....... uhm ..... that's all I've got.
I'm afraid that F1's prediction may come true. There may be some vinyl guru that can offer a "rabbit out of the hat" solution, so good luck !
Sal Palooza -
For fun and curiosity I smashed an old 78 into pieces, put them in a jar filled with denatured alcohol and waited for the shellac to dissolve. It never did.....guess that 78 wasn't made from shellac after all.Political Correctness'.........defined
Yeah....I was pretty sure what y'all would say. I may put them up on Ebay for some artist type to make something out of them, but Im tired of holding onto stuff.
You could make wall art out of them. I've also seen artist types make bowls with them.Political Correctness'.........defined
Bowls....wouldn't they melt when you lit the....oooh, sure. Like a container bowl to hold stuff
LOL.....yes, like a container bowl.Political Correctness'.........defined
Art project complete
Russ will pay you the $28k he has stashed in his truck for that.Political Correctness'.........defined
I remember a girlfriend of a guy I knew in school did that when she found out he was cheating on her.
Excellent work ! You could label this piece, "George Thorogood".
Decisiveness. That's a good quality in a person.
Sal Palooza -
Let's see, You started with around 50 pieces of fecal matter to pickup and now you've got what around 200-300 pieces of fecal matter all over the place to pickup.
Smooth move Ex-lax.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
PULL!
It was well worth the satisfaction of throwing them like frisbees.....
78? I pictured you as a bit younger!I remember a girlfriend of a guy I knew in school did that when she found out he was cheating on her.
Harvey Pekar is rolling over in his grave!
Interestingly, 78's do better than Digital download Karmas. -
It's the passion he used to smash the discs. It shows his angst and anger towards capitalism. Showing them that he will not conform to society!
Bravo! $28k is a bargain! -
Aw, man, you were on to something! (The job would go faster with bigger discs).
https://www.youtube.com/watch?v=GdKM4FvGGPY
