Any ideas of what to do
kevhed72
kevhed72 Posts: 5,243
edited September 2017 in The Clubhouse
With all these super crusty 78s....they all look retro cool but are brittle and dirty as heck....
    F1nut Posts: 52,406
    I see a trip to the dump in your future.
  • voltz
    voltz Posts: 5,384
    Avoid any alcohol based cleaners as the damage the Shellac.
    Audio Intelligent vinyl solutions has a cleaner called "Premium Archivist which is safe for 78's available from music direct...
    do some web searches for hints & as most say it is safe to use a little water and mild detergent.
  • mrbigbluelight
    It's been a bit since I've had vinyl, so I might be wrong (as if !) but I tend to think that vinyl and concrete don't mix in the most desirable fashion.
    So I'd recommend the following:
    Step 1: Remove albums from driveway
    Step 2: ....... uhm ..... that's all I've got.
    I'm afraid that F1's prediction may come true. There may be some vinyl guru that can offer a "rabbit out of the hat" solution, so good luck !
    F1nut Posts: 52,406
    For fun and curiosity I smashed an old 78 into pieces, put them in a jar filled with denatured alcohol and waited for the shellac to dissolve. It never did.....guess that 78 wasn't made from shellac after all.
  • kevhed72
    Yeah....I was pretty sure what y'all would say. I may put them up on Ebay for some artist type to make something out of them, but Im tired of holding onto stuff.
    F1nut Posts: 52,406
    You could make wall art out of them. I've also seen artist types make bowls with them.
  • kevhed72
    Bowls....wouldn't they melt when you lit the....oooh, sure. Like a container bowl to hold stuff
    F1nut Posts: 52,406
    LOL.....yes, like a container bowl.
  • kevhed72
    F1nut Posts: 52,406
    Russ will pay you the $28k he has stashed in his truck for that.
  • dromunds
    dromunds Posts: 10,175
    I remember a girlfriend of a guy I knew in school did that when she found out he was cheating on her.
  • mrbigbluelight
    kevhed72 wrote: »
    Art project complete
    Excellent work ! You could label this piece, "George Thorogood". :)
    Decisiveness. That's a good quality in a person.
  • gimpod
    gimpod Posts: 1,793
    Let's see, You started with around 50 pieces of fecal matter to pickup and now you've got what around 200-300 pieces of fecal matter all over the place to pickup.
    Smooth move Ex-lax. :wink:
  • kevhed72
    It was well worth the satisfaction of throwing them like frisbees.....
  • [Deleted User]
    78? I pictured you as a bit younger! :#
    dromunds wrote: »
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Harvey Pekar is rolling over in his grave! :o
    Interestingly, 78's do better than Digital download Karmas.
  • lightman1
    lightman1 Posts: 10,803
    It's the passion he used to smash the discs. It shows his angst and anger towards capitalism. Showing them that he will not conform to society!
    Bravo! $28k is a bargain!
    SCompRacer Posts: 9,404
    Aw, man, you were on to something! (The job would go faster with bigger discs).
    https://www.youtube.com/watch?v=GdKM4FvGGPY
