problem with polk audio dra 12
Hey. I bought a pair of speakers POLK AUDIO DRA 12. there was a problem with crossovers. Someone did not do a professional job with a soldering iron and now do not work tweeters. I ask you to send a diagram or photos of the correct crossover board.
Best Answers
Answers
    F1nut Posts: 52,005
    edited September 2017
    There is no such model. How about you post some photos of what you have.
  • on the crossover board it is written POLK AUDIO DRA 12 . what exactly is the model I do not know. I send photoszsqk6y3x9n7v.jpg
    F1nut Posts: 52,005
    It clearly says RTA 12 on the crossover board, so your model is the RTA 12.
    In your 3rd and 4th photos it appears one lead on the fuse is broken. The cause is the previous owner over drove their amp resulting in enough heat to melt the solder joint.
  • I also ask you to send either a diagram or photos where it is seen how correctly it should be that I am corrected on my crossovers. here is another photonq5pdyl95plg.jpg
    F1nut Posts: 52,005
    You need to solder the leads back onto the fuse block.
  • delkal
    delkal Posts: 764
    I have blown a fuse or two in the day........but cranking it up till the solder melts sounds awesome! :D
    Wish I was there to hear it (his speakers, not mine)
  • thanks for answers . I need photos of the bottom of the crossover board with the correct location of the contacts so I can fix it on my own
    pitdogg2 Posts: 27,325
    fireserzh wrote: »
    Then you need someone else to do the work. You have two speakers correct? Do both have the same problem? If not then your picture is before your eyes. Each side of the fuse block should have a wire coming to it find the wire and resolder it back to the side without a wire. I'm pretty sure I'm looking at the disconnected wire in your pictures pull it up wrap to the block the flow solder to the joint.
    If this is something you can't do its ok to admit that but all the pictures in the world will not fix it.
    This is a very simple fix
    Viking64 Posts: 7,626
    See the wire on the right that comes up through the hole in the board and is soldered to the fuse block? You need to make the broken wire on the left that is just poking through the board look like the right side.
  • thanks for the photo. from the plug out three wires, black must be pierced through the hole in the board and soldered to the fuse contact? I understand correctly?
    It's your photo....
    LOL
    Look at the other speaker for conformation it really is THAT easy
    I have 1000 memes for this, but sadly none of them are in Cyrillic. :p
    Viking64 wrote: »
    You noticed that to? License plate gave it away ;)
    Exactly. :D
  • dkfreebird
    dkfreebird Posts: 1,186
    It looks like you have 3 holes in the passive on the right speaker that needs some attention also.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
    dkfreebird wrote: »
    He is going to need photos of the passive on the right speaker that needs some attention with the correct location of the holes so he can fix it on his own. Thank you in advance. :p
    F1nut Posts: 52,005
    dkfreebird wrote: »
    If those puncture marks are limited to the outer layer the PR will not leak air.
  • about the passive membrane, I thought but for now I want to end with crossovers. not a professional soldering on both columns, so I can not compare how it should be properly done. spread more photos. From the bottom of the board under the fuse you can see that the piece of wire was soldered and closed straight. I'll clean it up. but I do not know which wire to solder to the second fuse contact. black wire from a three-core connector?c8udayj7vgng.jpg
  • I apologize for my language, I write through a translator :);)
    It looks like someone bypassed the fuse on both crossovers. With a short blue wire on one and with a short white wire on the other. If this was done previous to when you made this thread, I would guess that the fuse block not being properly attached was not your issue. If this is something you did AFTER getting our advice....
  • I bought the speakers in this condition. they were packed. now I want to remove all traces of non-professional repair and do as it should be.
    fireserzh wrote: »
    And this is where we should of started.
    Yes unless you have good quality high current amplification i would keep the fuse in the circuit. Most stereo/home theater receivers just do not have the amount of current needed for the RTA 12 speakers.
    Just my opinion
  • which amplifiers do you recommend? what do you think, 80 watts per channel will suffice? Now I have AKAI AM 2800 and the kit HITACHI HMA 7500+ HCA 7500.
    F1nut Posts: 52,005
    Here are the schematics for the RTA 12 series.
    http://forum.polkaudio.com/discussion/comment/434476/#Comment_434476
  • send please the photo from the bottom of the fuse so you can see what and where soldered
    txcoastal1 Posts: 13,519
    fireserzh wrote: »
    The first 2 pics show the bottom solder points
