SDA2B Upgrades
Cylontymany
What would be the best approach in upgrading these without breaking the bank? If I upgrade the tweet do I have to change the crossover too?
Replacing with 194s is a good first step and no, no mods are necessary for them to work properly.
I have a Sunfire 300x2 to make them sing
194s will be a significant improvement and require no mods. However, if you're planning future upgrades, the 198s sound even better and only require 1 additional 5.8 uF capacitor in each crossover.SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
RTiA3, Onkyo TX-SR605 -
Send them to me along with $500 and I'll upgrade them to a pair of Dynaudios and custom made stands with spikes.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Thanxs everybody. Are the 198s still available through polk? I just emailed them but wasnt specific enough.
Also forgot to ask what the mid woofers numbers should be when I pull them
6503 (stereo) and 6511 (dimensional).SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
And another-On the back of my SDAs they say SDA 2 I have the one tweet two mids and the large woof. Mine are the black wood colored ones. What do I have exactly?
That's a passive radiator, not a woofer. From what info you have posted they are likely 2B Studio versions. There would have originally been a B sticker on the top right corner of the rear label.Political Correctness'.........defined
President of Club Polk -
Thanxs F1 I couldnt think of the name of it at the time-I think they call it a brain ****! I think I will go with the R0198 tweets
You'll need to change the crossover to use them.Political Correctness'.........defined
Will the 198 fit or will I have to tweek the opening? As far as the crossover goes-just add the 5.8uf capacitor?
It'll fit.
At a minimum.Political Correctness'.........defined
It will fit with no modification to the opening. Schematics are here:
http://forum.polkaudio.com/discussion/55888/polk-audio-speaker-wiring-schematics-more-stereo-dimensional-array-sda
The "SDA CRS+ 1990 SL3000 Mod" drawing shows where the 5.8 uF capacitor goes. Note that the mid woofers are different in the CRS+. The 2B's use the same crossover but different mid woofers.SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
At a minimum.
+1. When budget allows, upgrading the rest of the crossover will bring huge improvements.
Looks like we were typing at the same time F1.SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
here a little upgrade tip, how about replace the screws that hold the driver 's & PR in with hurricane nuts and machine screws?
https://www.parts-express.com/parts-express-8-32-hurricane-nuts-50-pcs--081-1080
https://www.parts-express.com/8-32-x-1-1-4-black-machine-screw-button-head-security-hex--260-844
also if you do this you need to drill out the holes with several bits to slowly open the opening for the **** like 1/8 then 11/64 then 13/64 then 15/64 etc.. i think is how i did mine jeez cant no say hol?
and you don't drive in the hurricane nuts, but draw then in with a machine screw nice and slowly till they are seated.
the machine screws posted need a security allen type bit hex head to screw down.
like this one:
https://www.parts-express.com/1-8-security-allen-type-bit-1--360-225
add a copy 3x12 strip of blackhole 5 behind each driver going up towards top of cabinet.
I was planning on just doing the basic recapping and adding the 5.8uf for the 198s I am the best bang for the buck kinda guy so I dont want to try to create a whole new SDA
Yes, you do.Political Correctness'.........defined
What 5.8uf cap should i use-brand ect...
The same brand your using for the rest of the XO.
Cylontymany wrote: »I was planning on just doing the basic recapping and adding the 5.8uf for the 198s I am the best bang for the buck kinda guy so I dont want to try to create a whole new SDA
I'm a bang for the buck guy too. The mods voltz mentioned are big bang for little buck. I'm told these are improvements suggested by Mr. Polk himself.SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
The whole package makes a HUGE difference. -
Absolutely.
The caps, Sonicap comes highly recommended. Using Gimpods boards make the swap a complete joy.
Rings or hurricane nuts.
RDO-198's with the "TL" mod.
Black hole 5
These mods completely transformed my 2B's.
Worth every cent. -
Don't forget to glue the magnets to prevent shifting. Use Loctite Power Grab or JB Weld around the top and bottom perimeters of the magnets.
While you at it apply dynamat extreme on the driver and passive radiator frames too.
forum.polkaudio.com/discussion/171840/dynamat-installation-tip-for-tl3-1-and-maybe-others"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
While you're upgrading capacitors, don't forget to remove the 750 pF bypass capacitor. Also replace the polyswitch (safety guard on the schematic) with a 0.5 ohm resistor if you have an amp with adequate power.SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Where is the best place to get the RD0198s? Polk wont respond to me?
call them ...1-800-377-7655
don't email2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I missed this thread before.
So the consensus here is to remove the 750pF cap while using RD0194s?Don't take experimental gene therapies from known eugenicists. -
^^remove it when rebuilding the crossovers with better quality capacitors. Leave it as long as the crossovers are stock.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
