Auralic mini to linear ps cable
afterburntafterburnt Posts: 5,275
If anyone is familiar with this type of cable, what is it called and what would constitute an upgrade?
I think that this is the type, or at least this is what it mostly looks like, mostly.
https://smile.amazon.com/gp/product/B00OYZYYVS/ref=ox_sc_act_title_2?smid=A1KF3ITPY3ZC5Y&psc=1
  • afterburntafterburnt Posts: 5,275
    None of you eggspurts familiar with this type of cable?
    Is this a trick question?
    Oh I looked real close like and it has 3 prong holes.
  • WardswebWardsweb Posts: 791
    edited August 2017
    Did you get this figured out? The Amazon link is just an RG-59 coax cable with BNC connectors. This will not work for the Auralic linear power supply. That cable is a multi pin at the power supply end and something like a 2.1mm ac adaptor at the Mini end.
    Living room:Maplenoll turntable, Clearaudio Champion II turntable, Sonic Euphoria pre, EAR 834P phono pre, Shanling CD-T1500 sacd, Auralic Altair DAC/server, PS Audio Quintessence power, ASL AQ1006 845 DT MKII mono block amplifers, DIY Altec/JBL speakers
    Sun room: Roksan Radius 5 turntable, Lounge phono pre, DIY Class A 6H30 linestage, DIY 2A3 amp, Krell CDP, JBL C50 Olympus speakers with custom Smith horns, Klipsch Cornwall III
    Den: Onkyo TX-NR929 receiver, Oppo BDP-103 player, Panamax M5400-PM power, SST Ampzilla 2000 mono blocks, Behringer EP 4000 sub amp, Electrovoice DX-38 active, Klipsch Jubilee speakers, Martin Logan Cinema center, JBL SAT2 surrounds, Danley DTS-10 sub
    Wardsweb wrote: »
    Nope, I gave up. Nothing on the web.
    Look at upgrading you USB that feeds the music files. More room for improvement there. I use an Audio quest Carbon.
    I am using an internal drive
  • voltzvoltz Posts: 5,048
    afterburnt wrote: »
    me too :)
    Hey Darryl, get a load of this: http://forum.polkaudio.com/discussion/178464/noise-theory-internal-ssd-usb-hd-or-dnla#latest
    I want to get a really good USB cable and an SSD in an enclosure to test this.
    Let me know if you do! I curious but super happy as i stand or sit :)
    I think I can get a big spinner pretty cheap. I will let you know. dat gam SSD's are spensive!
Howdy, Stranger!
