Auralic mini to linear ps cable
afterburnt
If anyone is familiar with this type of cable, what is it called and what would constitute an upgrade?
I think that this is the type, or at least this is what it mostly looks like, mostly.
https://smile.amazon.com/gp/product/B00OYZYYVS/ref=ox_sc_act_title_2?smid=A1KF3ITPY3ZC5Y&psc=1
None of you eggspurts familiar with this type of cable?
Is this a trick question?
Oh I looked real close like and it has 3 prong holes.
Did you get this figured out? The Amazon link is just an RG-59 coax cable with BNC connectors. This will not work for the Auralic linear power supply. That cable is a multi pin at the power supply end and something like a 2.1mm ac adaptor at the Mini end.
Nope, I gave up. Nothing on the web. -
Look at upgrading you USB that feeds the music files. More room for improvement there. I use an Audio quest Carbon.
I am using an internal drive
Hey Darryl, get a load of this: http://forum.polkaudio.com/discussion/178464/noise-theory-internal-ssd-usb-hd-or-dnla#latest
I want to get a really good USB cable and an SSD in an enclosure to test this. -
Let me know if you do! I curious but super happy as i stand or sit
I think I can get a big spinner pretty cheap. I will let you know. dat gam SSD's are spensive!
