Turn my AVR into Preamp?
Kingkwas
Kingkwas Posts: 92
edited August 2017 in Electronics
Shortly after buying my Marantz AVR I learned abt the superiority of using an amp.
Can I just turn my Marantz SR5011 into a Preamp? Is there a drastic benefit to an actual Preamp?
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
  • BlueFox
    BlueFox Posts: 15,251
    If it has preamp outputs then it can be used as a pre. Most likely a dedicated HT processor (pre) will be better than an AVR used as a pre. It was for me.
  • dolbyd
    dolbyd Posts: 430
    Your Marantz has full pre outs on it. I would add an amp for sure.
    The Marantz is a good unit and will be a great Pre/Pro for you.
    I have a 5010 in the MB and I run a Adcom 7500 with it.
    Your LsiMs will be a lot happier.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA7 G3, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 80J 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • rooftop59
    rooftop59 Posts: 8,121
    I'll be honest...I went from a marantz nr1403 with an external amp for the mains to a Rotel RSP-1069 pre/pro (no built in amp) and then back to a marantz sr5007. The system is for netflix tv and music, and if anything the marantz sounds slightly better all around. The two channel music might have been slightly smoother on the rotel, maybe, but tv/movies sound sooo much better on the marantz. So I would just add an amp for the 703s and call it.
    FYI I finally upgrade to a rotel rb-993 200 wpc amp for the LSiM fronts, and that's when those 703s just really woke up. So I would recommend either a rotel rb-991 (the two channel version) or newer equivalent, or a parasound hca 1200 or 1500. Your ears will thank you...
    Game Room 5.1.4:
    Bedroom 2.1
  • I'm not sold on a separate pre. I get the amp part. More power is better.
    How is the pre/ processor better than just making my AVR the pre/pro?
    Thx
    R: Def Tech
    DVD: Oppo UDP 203
    pitdogg2 Posts: 27,055
    edited October 2017
    Kingkwas wrote: »
    Thx
    An AVR is like a jack if all trades and a master of none.
    A dedicated pre is just that dedicated to be a master of that function. Shorter signal paths, better implementation of the chips used for their purpose. Better components all around.
    An AVR in most cases has a price point it must meet. You take a 1500.00 pre-amp and a 1500.00 AVR that pre-amp will run circles around that AVR. It will also have a much lower noise floor than the AVR.
    Let me add some uber upper AVR's 5-6g range can be a whole different beast, but on a whole a dedicated pre-amp will out perform in most cases.
  • BlueFox
    Good answer, pitdogg2.
    tonyb Posts: 33,072
    The rabbit hole awaits young Skywalker. lol
  • I used to have a carver pre and when it puked (way too expensive to repair) I started using an older Integra dtr-7.1AVR receiver as a pre. I do think that the stand alone pre was a much better set up quality wise than the AVR. There are modern conveniences on the AVR that are kinda cool like zone 2 for the deck speakers outside but I will eventually change back to a stand alone pre when the wallet allows.
  • Many of the flagship AVR do everything in a very impressive fashion.
  • delkal
    delkal Posts: 764
    So what has more of an effect on the overall sound of your system? The amp or preamp.
    I know most here will say you need to spend big bucks on both........But pick one.
    tonyb Posts: 33,072
    delkal wrote: »
    No, most won't say you need to spend big bucks, just the opposite actually. My bet, the pre will make a bigger impact on the overall sound. Preferably a tubed pre.
    Viking64 Posts: 7,559
    I turned my AVR into a doorstop by hooking my Blu-Ray and SACD directly to my power amp. The sonic improvement was substantial.
  • gp4jesus
    gp4jesus Posts: 2,019
    Kingkwas wrote: »
    Thx
    @Kingkwas: one step at a time.
    *all connected w/Premiere ICs
  • gp4jesus
    Viking64 wrote: »
    simpler, more direct signal path is almost, if not always, better.
    edited November 2017
    gp4jesus wrote: »
    Yes. My 1999 flagship Yamaha home theater integrated amp was only seeing 44.1 KHz/16-bit from my Blu-ray via an optical cable. The internal DAC's of the player produce 192Khz/32-bit. I've read where some people say most people wouldn't notice a difference between the two, but I did an A/B test using both routes and switched between inputs on my amp, and it was a major improvement.
  • gp4jesus
    Viking64 wrote: »
    gp4jesus wrote: »
    please accept my upfront apology for sounding snobby. I would not know if a pre/pro* IS an upgrade from using an AVR as the same* - I've always had pre/pros; never had an AVR nor used same as a pre/pro though it makes sense.
    Good listening all, Tony
    tonyb Posts: 33,072
    Viking64 wrote: »
    gp4jesus wrote: »
    Most people don't know what they are listening for, which is why some can't hear a difference. How do you control volume with the BR and SACD connected to an amp ? Are you using an integrated ?
    Technically, I would say it was an integrated. It's a power amp that has a volume control and 4 inputs.
    tonyb Posts: 33,072
    Gotcha.....looks sweet too.
  • Upstatemax
    Upstatemax Posts: 2,737
    Viking64 wrote: »
    This is exactly why I no longer have a Parasound P5 in my 2ch system.
    It had to go back for service and while it was out, I just hooked my Oppo right up my amp. After some extended listening sessions, I made the tough decision to put the P5 up for sale.
    Tony M Posts: 11,623
    Wow !! What a BEAUTIFUL work of Audio ART !!
    That Amp is one I've never seen before.
    NICE !
    Thank you! I have been very happy with it. The build quality is excellent. Even the remote is aluminum. HAHAHA It produces more volume than an old metalhead like me can tolerate, and the sound it makes with my 2.3TL's is gorgeous, and I have yet to add my V3 crossovers, 198's, and dreadnaught into the mix.
