Want to stick my toe in the "power cord" pool...
13»
  • [Deleted User]
    DSkip wrote: »
    TForan wrote: »
    DSkip wrote: »
    On a side note, I've never liked the term 'noise' when it comes to audio. The perception is that it is something you can hear. It is actually quite the opposite. You never hear it, but it's damned clear when it's gone that it was there.
    You have to remember that a lot of older guys here don't have the hearing acuity of someone like you with young ears. Unfortunately, it happens to all of us. Super tweeters? Ya, right.
    I have some of the worst ears you can imagine. I've done a ton of critical listening to get where I'm at. Besides, if you get the room right, most of these changes slap you in the face. It's when the room is bad that you don't hear these changes - you hear the room and it's influence on the sound.
    Lots of guys 50 plus can't hear above 16K Hz. No room change will help that.
  • BlueFox
    BlueFox Posts: 15,250
    So. I am 68 with a bit of tinnitus in my left ear, and I can hear power cord, and other cable, improvements in sound. It is obvious. I have some state of the art power noise conditioning gear, and as Skip said, you don't realize the 'noise' is there until it is gone.
  • [Deleted User]
    BlueFox wrote: »
    At 68, lucky you. Not the norm.
  • ken brydson
    ken brydson Posts: 9,076
    TForan wrote: »
    DSkip wrote: »
    TForan wrote: »
    DSkip wrote: »
    What?
    F1nut Posts: 52,247
    TForan wrote: »
    DSkip wrote: »
    TForan wrote: »
    DSkip wrote: »
    Considering that there's very little above 16kHz except the very top end of the violin and female voice what does it matter? That's not to mention the discussion is about the benefits of lowering the noise floor and also room interaction. Why do you assume this applies to sound only above 16kHz?
    I'm over 50 and have no problem hearing differences in cables, gear and recordings.
    EndersShadow Posts: 17,747
    Your also immortal and superhuman.... that MAY play a small part in that lol...
  • Unknown
    edited August 2017
  • lightman1
    lightman1 Posts: 10,800
    DSkip wrote: »
    To further that hearing vs. listening comment, hearing simply means your ears picked up the noise. Listening means you actively processed the information. Critical listening is all about processing. It's about the brain, not the ears. :)
  • tophatjohnny
    tophatjohnny Posts: 4,189
    Unless you have a dedicated 20 amp line running to your gear, you are chasing your tail! Fact!!!!!
    Not always a viable option should you be renting a house/apartment. Its a step in the right direction and will help.
    That said, if your choices are dedicated outlet or powercable, I'd likely go dedicated outlet first, and run a couple at that.
  • [Deleted User]
    DSkip wrote: »
    TForan wrote: »
    DSkip wrote: »
    TForan wrote: »
    DSkip wrote: »
    I'm pretty sure I can't hear above 14khz. I also have partial deafness in my left ear. Yet, still my closest friends trust me and my ears. My system at LSAF was competing head to head with the best at the show and at a lower price point. My limitations did not impair my ability to piece together that system, although at times, I did call on more ears to confirm my hearing as you do tend to get exhausted at shows.
    I shared these issues with Jessica from North Star and she then shared this information with Francesco at Rosso Fiorentino. While I think Francesco was hesitant, Jessica had experienced the systems and synergies I had created at my house and heard me talk about how I went about building it. These issues did not cause concern for her, something she also shared with Francesco.
    I coach my clients and to forget about what they can HEAR and instead focus on what they can LISTEN for. This hobby isn't about hearing - its about listening. When you focus on limitations instead of growth, you never will know what you are missing.
    What was your lower "price point" for your entire system ?
    heiney9 Posts: 25,619
    TForan wrote: »
    DSkip wrote: »
    TForan wrote: »
    DSkip wrote: »
    This may be true in some cases, but many improvements heard with gear, cables, etc aren't in the upper ranges. People with diminished hearing can still detect improvement or degradation between gear and associated accessories.
    I'm over 50 (51) and I still have extremely acute hearing. The full frequency hearing maybe a bit diminished vs. when I was 21, but I assure you I can and do hear all kinds of things that others didn't notice or don't hear. Part of it is just awareness and I'm talking in everything, not just audio.
    In fact the girlfriend gets annoyed with me at times because of my acute hearing. But my hearing has always been a bit more sensitive than most around me. I'm always saying "what's that noise"? "Did you hear that"?. To looks of confusion and dismay. In fact many times I have to sleep with a fan or other noise because I lay there and hear every little thing and it keeps me from sleeping. Once I hear a noise, I can't unhear it or block it out.
    I've even sat and listened to audio with people and an constantly pointing out nuances of certain songs. Have to give the GF credit, when I point it out or tell her what to listen for, she does hear it and in some instance is amazed. But in audio that comes down to training yourself what to listen for, etc.
  • [Deleted User]
    Of course, this doesn't apply to anyone on this forum.
  • lightman1
    heiney9 wrote: »
    TForan wrote: »
    DSkip wrote: »
    TForan wrote: »
    DSkip wrote: »
    Does yout acute hearing match your acute derriere?
    I'm told it does o:)
    txcoastal1 Posts: 13,519
    Now I'm jealous :/
    TForan wrote: »
    Does it matter in this context? I can tell you there were systems 10x more spendy than Skips, and systems 2-3x LESS spendy than Skips.
  • K_M
    K_M Posts: 1,631
    TForan wrote: »
    DSkip wrote: »
    TForan wrote: »
    DSkip wrote: »
    With music, everything can affect the sound.
  • [Deleted User]
    That's not too bad of a price. Like to hear it. As long as I don't have to hear "Keith don't go" again or any of the other de rigueur audiophile demos.
    TForan wrote: »
    Skip played "Next Episode" by Dr. Dre and Snoop dog for me :smile:
    I have some more stuff for next time and am bringing it all with me digitally :smile:
    Lessons learned
  • [Deleted User]
    TForan wrote: »
    Lessons learned
    That's too funny. Middle aged white guys listening that stuff reminds me of this.
    https://youtu.be/XASNM1XEQPs
    ^Only diff is I don't roll my windows up :smile:
    And I look more cool than he does :grin:
    I woulda had him throw down some Skrillex and Diplo, but his room was POPPIN 24/7 so I didn't get a chance.
  • Joey_V
    Joey_V Posts: 8,603
    I was a nonbeliever for so long. But one day I tried it, and it sucked.
    Since then, I've had to shell out for these stupid cords.
    But yes, they work and they work well.
    I am a fan of Audioquest. It's what I stick with.
  • kharp1
    kharp1 Posts: 3,453
    TForan wrote: »
    I didn't really want to spend very much time in the spendiest room, just didn't gel with me. TETO
    kharp1 wrote: »
    TForan wrote: »
    Those horns were at least pretty to look at no :wink:
  • kharp1
    kharp1 Posts: 3,453
    kharp1 wrote: »
    TForan wrote: »
    Absolutely, they were gorgeous!
    Now that I think about it, I didn't really care for the second spendiest room either.
    edited August 2017
    kharp1 wrote: »
    kharp1 wrote: »
    TForan wrote: »
    My fav setup were Russmans, Skips and then surprisingly the little bookies on the desk in the GR room and the Black Hole room
  • CH46E
    CH46E Posts: 3,595
    Im not sure if anyone mentioned "Marrow Audio". They have some pretty good sales a few times a year.
    I was going to buy 2 powercords . One for the Belkin PureAV PF60 (would have to hard wire it in) and the other for my Parasound 2250 v2. But life stomped that out for the time being!
    Anyone have experiance with thier products?
