Cable Elevators ~ part deux
First let me say that I've long given up caring as to whether cable elevators have any effect on the sound, so no one needs to go there.
I purchased ten wooden cable elevators years ago from Russ Andrews and painted them flat black. They are used to support the MIT speaker cables in my big rig. However, one thing bothered me a bit, they are very light weight, so a bit tippy. Over the years I thought of various ways to make them heavier, but since that was really low on the list time just slipped by until last week when I got the serious bug. I found some 2" diameter, 3/8" thick 316 stainless steel discs. I used 3M double sided ultra thin adhesive to attach the disc and put a self adhesive rubber disc on the very bottom. This is the result of which I'm beyond tickled.
I'm so tickled with these that I've ordered a boat load more cable elevators, discs and rubber pads to do my other rigs. B)
    pitdogg2 Posts: 24,624
    Shaking my head ....
    BLING BLING
    Pretty cool Jesse.
    msg Posts: 9,493
    Dag Jes, those things look pro finished. Very nice.
    How long 'til they're fully broken in?
  • ken brydson
    ken brydson Posts: 8,658
    Inquiring minds want to know where you sourced the elusive black paint.
    F1nut Posts: 49,850
    msg wrote: »
    200 hours, it's always 200 hours.
    F1nut Posts: 49,850
    I lied, there is no black paint, it's a dye. >:)
  • Dennis Gardner
    Dennis Gardner Posts: 4,860
    edited August 2017
    They look factory to me......but then again, I've never seen an elevator/riser factory so what do I know?
    On cable risers and carpet I never can remember, isolate or insulate? I think risers with miniature spikes might be overkill.
  • Legender
    Legender Posts: 478
    Regardless of the sound impact. That's pretty cool. Very sharp.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
    mhardy6647 Posts: 33,090
    That explains it! Else I was gonna ask you to out your source...
    msg Posts: 9,493
    Psssh - No such thing!
    I think 3 spikes per elevator, minimum for stability. Or outriggers.
    Also, core out the aluminum base, fill with lead shot. Finish by pouring the contents of a Cards Quad filled solder pot over the shot to fill any voids. Or in a pinch, Play Sand as a second best alternative. Next to depleted Uranium, I mean.
    msg wrote: »
    I thought it was 10,000 hours... ;)
    http://www.businessinsider.com/new-study-destroys-malcolm-gladwells-10000-rule-2014-7
    oh, wait, that's been debunked...
  • steveinaz
    steveinaz Posts: 19,522
    Very elegant.
  • nspindel
    nspindel Posts: 5,343
    I heard that a layer of BH5 between the riser and metal disc can work wonders for bass extension and imaging.
    heiney9 Posts: 25,092
    Sleek and elegant!
  • Jhayman
    Jhayman Posts: 1,548
    They look Professionally made, Very well done Jesse.. :)
  • DaveHo
    DaveHo Posts: 3,481
    Very cool looking. Inquiring minds want to know. How much does each assembled unit set one back?
  • machone
    machone Posts: 1,484
    Very nice!
    My Belden cables would look great displayed on them >:)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    msg wrote: »
    Scott it's 316 stainless. Not aluminium. If you would just melt and pour the lead shot there would be no need to waste the Cardas solder...
    I mean come on man think this through :p
    F1nut Posts: 49,850
    edited August 2017
    DaveHo wrote: »
    Materials and labor plus a profit margin.....I think you'd be looking at a retail price of $50.00 each.
    Post edited by F1nut on
  • vmaxer
    vmaxer Posts: 5,116
    Looks great.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • machone
    Hey Jesse,
    Where did you find the ss discs?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    msg Posts: 9,493
    msg wrote: »
    lol, dangit, morning speed-reading; bah; I read 'stainless' but changed it to al-yoo-min-eeum in my mind.
    I thought about just melting the lead as well, but... well... eh, ah, forget it.
    msg Posts: 9,493
    Jesse, did those rubber discs come sized just so, or did you have to cut them? The look clean and appear to fit perfectly. Curious where you sourced them.
  • stones89
    stones89 Posts: 229
    You know they must be cryoed. Have you put them in the freezer for the minimum 1300 hours. Seriously, they look like audio jewelry.
    Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's
    F1nut Posts: 49,850
    It's all out there, you just have to look for it.
    Toolfan66 Posts: 16,947
    They look fantastic!!!
    Great job Jesse!!
    EndersShadow Posts: 17,543
    You sir are not allowed to talk that way.... I refuse to search for things :smile:
  • mikeyb128
    mikeyb128 Posts: 2,885
    Those look great. I made some out of solid oak, stained and laboured. They look cool, didn't notice any change in sound.
    2 channel:
    Theater:
  • mikeyb128
    ^^^ lacquered not laboured
    2 channel:
    Theater:
