The LP Lover's thread...
124
  • Wardsweb
    Wardsweb Posts: 942
    SCompRacer wrote: »
    One of these days my table will match my Walnut Bottlehead Eros phono stage...a PTP5 stainless top plate Lenco. The motor is separate of the main bearing plate. I'll keep my air bearing linear, maybe stick a pivoted arm on it too.
    Nice wood working! You have skills.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited July 2017
    Some gorgeous tables shown here, my current Deck.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Just picked up this guy tonight.
    I hate doing dishes but I'm excited to wash records? What's happening to me?!!
    2 channel:
    Theater:
    txcoastal1 Posts: 13,514
    mikeyb128 wrote: »
    If you're married.....Divorce :)
    treitz3 Posts: 20,057
  • FestYboy
    FestYboy Posts: 3,861
    @treitz3 , thanks for the unobtainium wish list... :#
    Since I'm new to the game and have permission to procure a new to me TT, are there any recommendations for a budget minded "starter" table? I know anything will be an improvement over the Panasonic that I'm currently using... I'm thinking the $500 range... So I know I'll be looking at the used market.
  • mikeyb128
    Before the Nottingham I picked up a musichall MMF 7.1, and that was a fantastic sounding table for the money. I don't have much experience in the TT realm, but I'm sure others will recommend something vintage.
    2 channel:
    Theater:
    mhardy6647 Posts: 35,162
    not mine -- but about as good as it gets.
  • motorhead43026
    motorhead43026 Posts: 4,019
    ^^I like the high tech isolators. I use those under all my equipment.
    – Kevin Alfred Strom
    I've got some, too :)
    The Fairchild tables were all pretty nice, and the 750 is the sine qua non.
    This one's "only" a two-speed -- note the stick shift.
    msg Posts: 10,452
    SCompRacer wrote: »
    Hey Rich, which light/lamp is that that you're using for your turntable?
  • K_M
    K_M Posts: 1,631
    Glad to see this thread -- I have nothing of substance to add (imagine that?!) ;) but I will cogitate and chime in if I can cobble up something profound or interesting to say.
    I still think that the resolution of analog records, and photographic film (for that matter) cannot be beat.
    I really like the sound of some of our vinyl and its fun to play at times.
    Not a die hard vinyl person though, I will admit, but your comment about resolution got me curious.
    I kinda thought the actual resolution of vinyl was lesser than all digital sound formats, due to partially the buit in noise floor being relatively somewhat high in comparison to digital
    Or are you talking about in some other way?
  • steveinaz
    steveinaz Posts: 19,545
    I think he means resolution is terms analog having infinite "samples"....
  • indyhawg
    indyhawg Posts: 1,673
    edited August 2017
    mikeyb128 wrote: »
    I thought I had a nice table, until I see the tables above. Lots of really nice tables here gentlemen.
    I agree.
    SCompRacer Posts: 9,121
    msg wrote: »
    SCompRacer wrote: »
    I stole it off our BBQ grill! I think the wife bought it. It has a clamp, batteries with switch in the clamp end.
    I see Amazon has them....mine doesn't have holes in the reflector though.
    https://www.amazon.com/LED-Concepts-Grill-Light-Bright/dp/B01F7RO4YS/ref=sr_1_4?ie=UTF8&qid=1502227657&sr=8-4&keywords=clamp+on+grill+light
    edited August 2017
    K_M wrote: »
    .... due to partially the buit in noise floor being relatively somewhat high in comparison to digital
    You might be amazed at how low the noise floor with vinyl can be. That is no hiss or hum while playing and no hiss or hum when you lift the needle to stop the playing. With a micro-line stylus you get deeper in the groove of a record. This helps with used records where other types of stylus were used and the records and stylus were not kept clean. That means no tics and pops and a quiet back ground. Darn amazing.
    I put a lot of money into a DIY DAC with discrete balanced output (no op amps) and it sounds fantastic, yet everyone prefers the vinyl playback here. My vinyl has incredible bass, midrange and highs. Goosebump type stuff.
    msg Posts: 10,452
    edited August 2017
    Dag, Rich, nice, I like the sound of that. What are some examples of micro-line stylii? Perhaps, something I might run on a Technics 1210.
    Thanks for the info on the lamp!
    Good laugh.
    I have one of these in place for now. Gonna see if I can get some dimmer colored LED blubbs for it, or maybe make some gels, but going to see about one like yours. I like the nice subtle lamps I see in some of the tt setup photos. If nothing else, I can identify it for... the grill.
  • mikeyb128
    I think clean records help with noise floor ALOT! Just because they are new doesn't mean they are clean either. I couldn't believe how quiet vinyl can be until I heard a Nottingham. And most recently transrotor. Stylus shape as other have already mentioned Is huge, my Carmen is very quiet, and pulls incredible details from a record. I feel most people haven't heard a good anolog setup before.
    My first TT (a teac TN300) was utterly disappointing.
    2 channel:
    Theater:
    edited August 2017
    msg wrote: »
    My AT33PTG/II has what they call a MicroLinear stylus. Different manufacturers use different names for the fine line stylus so tough for me to come up with suggestions right now.
    Here is a good read from SoundSmith.
    https://www.sound-smith.com/articles/stylus-shape-information
    "Then, there are the "fine line" styli, including standard Contact Line, as well as the more esoteric evolutions such as Shibata,  Micro Line or Ridge, Optimized Contour Contact Line (Soundsmith) and so on. These are almost always nudes, for lowest possible mass. These designs have a sharper edge (radius) that play the record groove walls, which allows better high frequency reproduction (especially at the inner grooves where it is more difficult) resulting in lower distortion, better imaging, depth, and many other aspects of fine analog listening that are lost when the high frequencies are not resolved as well - usually by lower quality stylus shapes. "
  • PSOVLSK
    PSOVLSK Posts: 5,396
    mikeyb128 wrote: »
    I'm sure that is a very accurate statement.
    See signature.
    edited August 2017
    When it comes to accurate (ahem, if you will, high fidelity) reproduction of a waveform, I'd opine (with characteristic humility, of course) that resolution is an "issue" in two dimensions: amplitude (y) and time (x). Analog storage of waveforms has it all over digital when it comes to resolution in the time domain (again, I'd opine, being well aware that there are probably volumes of data from Nyquist on down that "prove" otherwise) -- if for no other reason than it is so much simpler to extract and transduce data from a record groove to a loudspeaker than it is to get it back from the digital domain, translate (back!) to analog, and then transduce. [EDIT: whoa, that paragraph is worthy of Henry James in terms of its wordiness and impenetrability, sorry!]
    In theory, though, I'll grant you that the ultimate s/n in the digital domain is better than vinyl. Probably not better, believe it or not, better than 15 ips half-track tape, though... but that's definitely another story for another day ;)
    EDIT: By way of a diversionary rhetorical tactic* :) I'll remind us all that research into "perceptual encoding" led us to a plethora of "lossy" formats which, the experts insist(ed), encodes all of the perceptually important information from that original, analog waveform into a compact digital format (e.g., the MPx standard) -- and we all know and love the perceptual encoding of MP3, right? ;)
    ___________
    * One will note that this appendix has nothing to do with the original topic! :)
  • Mike Reeter
    Dawgfish wrote: »
    Thanks! I am a big fan of the 103 family. I also have a 103D and 103M. I would like to have a 103SA one day, but I haven't found one yet for a price I would consider pulling the trigger on.
    If you need any help/advice with anything 103 related, hit me up anytime. Oh and couldn't agree more with having threaded inserts! Makes life so much easier. Just be careful with the wood bodies and the screws. It is possible to overtighten the screws and strip the wood threads.
    I sent my 103R to Terence at Paradox Audio last week and he removed it from the original plastic body, installed and potted it into one of his Pulse Bodies and returned it, all within 24 hours.
    Good Lawd, this Sombitch Sings!!!
  • Dawgfish
    Dawgfish Posts: 2,554
    edited August 2017
    Oh wow! Congrats! That seriously kicks butt and the looks are gorgeous! You have a really sweet setup!
  • Dawgfish
    PSOVLSK wrote: »
    mikeyb128 wrote: »
    Yep! I love Ken's tag line "The easiest way to enjoy digital is to never hear a good analog setup"! I think that sums it up perfectly!
    msg Posts: 10,452
    Verrry nice, Mike.
    Dawgfish wrote: »
    PSOVLSK wrote: »
    mikeyb128 wrote: »
    I'd have to agree. My favorite analog is RTR. Either way it's a rabbit hole that I try to avoid, because once you start, it's another addiction
    Love going to Luther's and listening to his multimedia set-ups
  • mikeyb128
    Dawgfish wrote: »
    Do you need a heavier counter weight to run this? The paradox is 14 grams?
    2 channel:
    Theater:
  • Mike Reeter
    mikeyb128 wrote: »
    Dawgfish wrote: »
    Not on my arm, I can adjust the weight a considerable amount. I have a VPI Unipivot, I can see where it would be an issue for a few arms. I've read where some use a Lead Tape to add offset the heavier body.
