Good inexpensive 3.5mm to 3.5mm cable and .25" adapter together or seperate
afterburnt
afterburnt Posts: 7,892
Looking for a durable upgrade for Audio-Technica ATH-MSR7 cheap but good.
Merci
  • voltz
    voltz Posts: 5,384
    edited July 2017
    oh man I had a adapter for you the does they 1/4 to mini jack made by Grado that is excellent. I should have sent you. the other way around .25 to 1/4 or 3.5
  • afterburnt
    voltz wrote: »
    I could use both small to large and large to small because of the extension. The adapter that I am using with your Micro is pretty temperamental but it all depends on which cans and cables. Some of these OEM cables that I have are like thin as thread. I will look up the Grado and see if I can get one.
  • voltz
    voltz Posts: 5,384
    it came with some Grado cans I sent Scott/msg... I use it from my PC to my SENN 598's
  • voltz
    voltz Posts: 5,384
    Bingo, my brother!
