"Universal" headshell recommendations/suggestions
mhardy6647
I'll tell you why I'm asking anon
Can you rekkid playing folks suggest or recommend good quality "universal" style headshells -- i.e., the traditional four-pin bayonet mount "SME style" headshells commonly used for the traditional Japanese "S" shaped tonearms?
Specific vendor recommendations are also greatly appreciated.
I am one of those old-fashioned fogies who would rather not buy from some shadowy eBAY vendor whose mailing address is a PO Box in Outer Higgeldypiggeldystan, you know?
Thanks!!
spinnin3 by Mark Hardy, on Flickr
PS "Reasonably priced" is good, too!
Thanks!!
spinnin3 by Mark Hardy, on FlickrPS "Reasonably priced" is good, too!
Would this one fit your sony. I use this as a backup headshell.
https://www.amazon.com/gp/product/B000WMGM7G/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
That's the same one I bought awhile back. May depend on what cart you're using re: weight
Yes it should fit.
Weight is manageable
It'd be nice to have something that'd let me get the cartridge a little further forward than the (one) head I've tried so far.
The arm is an A-T (not that I am sure which one).
This Sony is good.
Listening to Ms Ronstadt now and it's 1977 all over again -- in a good way.
Very nice looking direct drive 'table Mark! Once you clear off the dust I bet it'll be super purdy!mhardy6647 wrote: »
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
It's not junk.
My friend Alan & I set it up yesterday -- we were both surprised (his word, "amazed") by how dead quiet it was. I thought the SL-2Q was quiet. This beast is in another league.
