Fidelizer
This works remarkably well, you simply must try it.
  • machone
    machone Posts: 1,566
    Ditto, I've been using it for about a year.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    mhardy6647 Posts: 35,237
    all righty then. I have no clue what it is (assuming it is an actual physical thing and not some sort of software thingie).
  • machone
    edited July 2017
    It's PC software that shuts down background processes that are not required for audio.
    I started with a laptop using JRiver and added Fidelizer. I liked the improvement and decided to change to a small low powered all solid state computer to lower noise even more. It definitely improved the SQ. I changed the computers wall wart power supply to a Mojo Audio Joule v5 power supply and that made more improvements.
    The point is that I have found that a cleaner and faster the power supply along with less background processes equals better sound. :)
    Forgot to add: Get rid of the moving parts; go solid state.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    seems plausible enough.
  • afterburnt
    afterburnt Posts: 7,892
    machone wrote: »
    http://forum.polkaudio.com/discussion/178018/ifi-ipower-hans-says-these-sound-good#latest
    This is one of the reasons I asked about these, especially considering the price of the linear that you have. I have to try one of these on my PC since I play music on it a lot still.
    billbillw Posts: 7,800
    Or, just use a small Linux OS like Daphile, which doesn't have anything extra running in the first place... :wink:
    I guess if you have to have Windows, something like this is good.
