Hafler 500 Upgrade
Last night I upgraded the driver boards on my Hafler DH-500 to Musical Concepts PA-6 Elite.
Powered it up, set the bias and DC offset. All good!
I plan to put it back in the rack tonight and start the burn in process.
These boards are supposed to be quite an improvement as they are more transparent without adding brightness or etching.
We shall see...
We shall see...
1KVA Dreadnought
Marantz SA 8005
Sony PS4
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Other; S60'S, M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
There are three things that give a man a false sense of courage, a keyboard, alcohol and a firearm.
Motorhead, 4.12.20
tonyb said " but even socialists can do a good thing here and there
the substitution of politics for existence is the supreme betrayal of the subjective otherness of man.
Silent background and huge soundfield with effortless power.
Got the radio playing continuously to help burn in.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
24 hrs = not good
48 hrs = not good
72 hrs = beginning to change
96 hrs = now we are talking
The thing I don't get is why it sounded good at power up but at 24 hrs it did not impress and at a level that I was wondering about my decision to upgrade?
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Motorhead, 4.12.20
I have a Hafler Trans Nova 9300 THX that I've been considering recapping. Anyone have any experience with this model?
Hearing vocals and instruments never heard before. Things like brushes on a snare or the crash of a cymbal out the blackness. It's dead quiet at any volume. More transparent than ever but very natural without any harshness. The dynamics are explosive and contolled.
This amp seems invisible. I am impressed!
1KVA Dreadnought
Marantz SA 8005
Sony PS4
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Motorhead, 4.12.20
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Glad it's meeting your expectations so well.
I got a 220 sitting in a box somewhere.
Motorhead, 4.12.20
Call John. He will set you up with what ever you need.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Motorhead, 4.12.20
It's great. Slowly but surely it just keeps getting better. Smoother with no fatigue; so natural!
1KVA Dreadnought
Marantz SA 8005
Sony PS4
My fan only runs on low. With everything else in the room turned off I can hear the fan but only if I listen for it. FWIW it does not register on my DB meter.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
I get it.
The Musical Concepts stuff is not cheap. I bought my DH-500 back in the 80s, it finally stopped working so rather than change out a few parts to get it going I decided to have them rebuild it using their PA4 driver boards. Since then I have been slowly upgrading binding posts, IEC inlet, power cord, Dynamat and things like that. This time I upgraded again to their PA6 driver boards AND they just came out with a new power supply upgrade using Jensen 4 pole caps and their CRC design. This upgrade sets you up for their dual toroid transformers.
Sky's the limit
I does sound great though
1KVA Dreadnought
Marantz SA 8005
Sony PS4
It's like a B52 with new engines and avionics.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Original 650 watt transformer.
New dual 500 watt toroidal transformers.
Got rid of the mechanical t-former hum and sets me up to go with a dual mono power supply in the near future.
Also upgraded all of the primary power wiring.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
I expected mechanical t-former hum to be reduced and it has been reduced to a level that is not noticeable unless I am right next to the amp.
I expected the bottom end to be more dynamic and it is.
I did not expect the whole sound stage to open up x,y & z. Separation of instruments and voices are more precise and the overall image is just spectacular.
Everything is more natural drawing me into the music. Background "noises" in certain songs are now separated and understood. For instance, Muse is one band that uses some weird synthesized notes that sounded like noise but are now understood even I don't know why they would choose such bizarre notes.
I could go on and on but I guess my learn from this upgrade is power wiring and power supply hardware made a huge difference in this amp. And yes, don't forget the power cord............
1KVA Dreadnought
Marantz SA 8005
Sony PS4
I plan to change out the two existing power capacitors (39,000uF 100Vdc each) and the original rectifier with a dual mono capacitor/rectifier kit. There is one capacitor board and one hyperFRED soft recovery rectifier for each channel and they will be fed by dedicated toroidal transformers (installed earlier this year). Each board holds four snap in style capacitors. I can order the boards and stuff them with my choice of capacitor.
I am looking at eight Mundorf MLytic AG caps (15000uF 100Vdc each).
Does anybody have experience with these caps in a power supply?
Thanks............
1KVA Dreadnought
Marantz SA 8005
Sony PS4
1KVA Dreadnought
Marantz SA 8005
Sony PS4
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Waiting on the circuit board kit.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
