Phono Preamps
DaveHo
I'll be one of the lucky to participate in the Vista Audio Phono-2 tour @DSkip is putting together. I'm looking to order in a couple others so I can do a comparison when I receive the Phono-2. My current cart is an Audio Technica 440mla which is on the lower end of output for an MM cart, so I'd like something with adjustable gain. It would also be nice to be able to play with cart loading since the Phono-2 is so versatile in that regard. Probably going to pick-up a Pro-Ject Tube Box DS for the comparison & would like to grab one other.
Does not have to be tube based. Looking for those costing under $500. Needs to be new so I can return the losers. Who has suggestions?
For reference my current rig consists of:
Pro-Ject Debut III, AT 440mla cart, Acryl It Platter & Speed Box S
Cambridge Audio 640P
Parasound P5
Aragon 8008x3
Polk LsiM705
Parasound P5
Aragon 8008x3
Polk LsiM705
For that budget you can get a (used) Leahman black cube SE. Has all and more than you mentioned and you may not want to send it back.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
http://www.loungeaudio.com/lcr-mr-iii
This is a very popular budget phono pre over at SHF. 40dB of gain, passive LCR network.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Will look into those. Thanks.
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
That speed box & Acrylic platter were a nice improvement for your TT.
I think your phono amp is a decent one, but if your lookingto upgrade it I recommend the Vincent PHO-8 for $300 or the PHO-700 for $500
http://www.audioadvisor.com/prodinfo.asp?number=VIPHO7002 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Mikey081057 wrote: »
I know of the budgie's reputation, but my cart's output falls short of the recommended 5mV min. Thanks for the suggestion. -
I've been considering a Budgie for use with my AT440MLa cart. I never saw a minimum cartridge "output" requirement listed by Parks Audio for the Budgie. The output listed for the AT440MLa on the AT website is "4.0 (mV, 1 kHz, 5 cm/sec)." I would like to know the answer to this after reading Dave's comment. Also wondering if the Budgie would work with my Denon HOMC DL-160 cart. It's output voltage listed as 1.6mV, would I require a SUT using a Budgie? Not trying to derail Dave, you just brought up the Budgie 5mV min. recommendation I just need clarification/advice too. I know I can call Parks Audio, but you guys know everything and I can be real dumb on new things
Thank you. -
Love mine, and would recommend.
2 Channel "Polk" Room:
Marantz PM8004 Integrated
Marantz SA8004 SACD Player
WiiM Mini
Polk 7B with RDO198s -
aprazer402 wrote: »I've been considering a Budgie for use with my AT440MLa cart. I never saw a minimum cartridge "output" requirement listed by Parks Audio for the Budgie. The output listed for the AT440MLa on the AT website is "4.0 (mV, 1 kHz, 5 cm/sec)." I would like to know the answer to this after reading Dave's comment. Also wondering if the Budgie would work with my Denon HOMC DL-160 cart. It's output voltage listed as 1.6mV, would I require a SUT using a Budgie? Not trying to derail Dave, you just brought up the Budgie 5mV min. recommendation I just need clarification/advice too. I know I can call Parks Audio, but you guys know everything and I can be real dumb on new things
Thank you.
From the Budgie's specs:
Gain: 38dB (suitable for carts with at least 5mV output)
This cartridge output requirement is still confusing me, especially after reading this https://forum.audiogon.com/discussions/mv-output-from-cartridge-please-explain
I'm going to check with Parks Audio and report back on the "at least 5mV output" statement they list, I saw it on their Budgie website page too. -
so-- if I can do arithmetic right (with a calculator!), the difference between 1.5 mV and 5 mV, after Bob Harley* (reference below), is 10.4 dB. In other words, you'd lose 10 dB of output (a factor of 10-fold, potentially, in terms of volume) with a 1.5 mV cartridge relative to a 5 mV cartridge.
*Now, I've gotta admit, I am not at all sure why the delta is 10.4 and not 5.2 dB... maybe the factor of "20" Harley used was because there are two channels (stereo)?
reference: http://www.theabsolutesound.com/articles/taking-the-guesswork-out-of-phonostage-gain-1/
Remember, also, that the cartridge output specs are nominal -- usually referenced to a certain frequency and groove velocity (1 kHz @ 5 cm/sec peak, e.g.,https://forum.audiogon.com/discussions/mv-output-from-cartridge-please-explain). In practice (of course!) both frequency and velocity change (a lot!) when playing an actual record containing actual music!
Now, 10 dB is a lot of difference in signal (and, ultimately, loudness). If nothing else, the s/n will be that much worse at any given listening level... but it does NOT mean that a 1.5 mV nominal output cartridge won't work with the phono preamp in question. The question would be "Will it let me play my rekkids loud enough to satisfy me?". I'd opine (ahem) that's a question that can only be answered empirically
All this being said, it sure is nice to have options in terms of gain (and loading!) in a phono preamp. Today, thanks to the resurgence of interest in playing records, there are reasonably priced options that give one much flexibility.
The Schiit Mani, e.g., would be well worth a look, I would think! A lot of capability in a cheap package! Mind you, I've never heard one, so it might sound like... you know... Schiit, but even if you didn't like it, it's probably returnable and even if it's not... it would probably be easy to sell it and recoup most of one's investment!
Best case, maybe you've got a friend who's got some Schiit?
http://schiit.com/products/mani
The aforementioned Schiit Mani offers four different gain options: 30 dB, 42 dB, 48 dB and 59 dB, and loading options that should
support most MM, LOMC and HOMC cartridges reasonably well.
Is that cart something you're married to?
Seems like a different cart might be a consideration before collecting phono pres?I disabled signatures. -
Good point
There are so many good phono cartridges available at all price points -- the only real difference between today and the halcyon days of record playing is the lack of truly good, cheap cartridges. In 1979 or so, the Grado FTE+ (more or less equivalent to today's Grado Black) was thirteen dollars. I bought one for my parents way back when -- a very good cartridge then (and still a good sounding one now to my ears). The conical stylus Grado of the same era (FCR+, I believe, was the model) was nine dollars.
I mean, one could invoke inflation and say that $13 then had the buying power of $46.58 today (https://www.bls.gov/data/inflation_calculator.htm), but the CPI doesn't really do a very good job of estimating price over time for electronics
Grado stylus pull3 by Mark Hardy, on Flickr -
The 440mla tracks like no other at it's price point. I've tried a few others, but could never get rid of IGD until I tried the AT. I will upgrade the table/cart at some point, but not now. That's part of the reason I'd like a flexible pre, future proof. I don't think the current table is worthy of a more expensive cart. -
@DaveHo : I have a Schiit Mani gathering dust if you want to try it. They are known for RFI issues, but if you're clear of any nearby FM transmitters, it might be worth a try. I didn't realize I was that close to a transmitter, but apparently I am! PM me if interested."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
That lounge audio LCR is awesome! It sounds way better than it should for the measly 300 it costs. And the build is solid.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
It has some informed fans on the vinylengine forum as well, and that's a good thing. I am pleased with my investment in my Pro-ject PhonoBox DS+, but I would not hesitate to try the Lounge Audio if the opportunity presented itself.That lounge audio LCR is awesome! It sounds way better than it should for the measly 300 it costs. And the build is solid."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I sold it, and kicking myself to this day for not keeping it. My EE is much better, but that lounge would have been one heck of a backup.2 channel:
Theater:
FWIW I found myself looking for a pre due to the the Denon receivers phono section sounding like the .40 cents it was worth. I tried the Bellari. https://www.musicdirect.com/phono-preamps/bellari-vp130-tube-phono-preamp
It did sound pretty good but was more than I needed. Option wise and price.
I wound up with the NAD PP2.
https://nadelectronics.com/products/all-amplifiers/pre-amplifiers/
I was really impressed with this budget phono pre. No frills, no adjustments just very good sound with plenty of gain. I am upgrading this to the NAD pp4 with the USB out so I can copy some records. It should have been in last week but...
Just a thought for a nice sounding phono pre well within the price range.Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
I have not tried the iFi iPhono but some of the reviews make it interesting.
https://analogplanet.com/content/whats-8500-cartridge-doing-place-399-ifi-iphono-phono-preamplifierintegrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
I have a Lounge Audio LCR that I use for backup duty. Like the others have said, it offers great bang for the buck and I don't hesitate to recommend it.
If you are willing to change your mind on a used unit, I highly, highly recommend a Jolida JD-9. They sound good stock, but can be taken way up the latter with relatively easy and inexpensive mods. They are very adjustable and compatible with virtually any cartridge out there should you decide to experiment with different cartridges in the future. Read up on the DYI articles on modifying this unit. I and others here on the board can verify the glowing reviews of modded JD-9s are very much spot-on.
