Surroundbar 4000 IHT
bpkamrath
I recently purchased this unit on 3/28/13 and just now have had the opportunity to hook it up. First problem was the optical plug would not accept the optical cable. Turned it upside down and pieces of plastic fell out. Used the RCA jacks instead, but no sound. Shout off TV speakers and still no sound. I am in a quandary as to what to do. Need help big time!!!
Post edited by bpkamrath on
Hello bpkamrath,
Welcome to Polk's forum. On the toslink digital cable keep in mind there is a rubber protector that has to be removed before it will fit into the digital connection. If you are using the analogue RCA connections make sure you've set the Polk to the correct input. Also you might have to use the TV's remote to increase the level of the signal coming into the SurroundBar. If you're still having a problem telephone Polk's CS department at 1-800-377-7655 and they can help.
Regards, Ken -
Thanks Ken,
On the toslink digital cable, there wasn't a rubber protector on the cable. The plastic pieces that fell off came from the sound bar. I looked liked someone had tried to hook this unit up before I bought it. I'll connect Polk's CS dept. if I have further troubles. -
No problem, glad to be of help. The broken plastic piece may be the small latch that holds the toslink cable into the connector, without it the end of the cable won't stay in place. Best to contact Polk for that.
Cheers, Ken -
i have a polk sound bar 4000 and no sound! Any ideas all lights on sub is sinked
Hello,
Welcome to Polk's forum. Can you give us a little more detail? How have you connected it to the rest of your system? What are your source components?
Regards, Ken -
It's connected directly to the cable box I do have power coming out of the audio of the cable box checked it with my earphones all the lights turn on on the bar and I'm connected to the subwoofer but no volume
Correct Source light is on the sound bar
You are using the "aux" input, correct? Meaning this is an analogue connection as opposed to a digital connection, correct?
correct, was working fine then quit producing volume
Is there something you could substitute as a source? A CD/DVD player maybe?
I shut it off for a while hooked it back up worked for a minute then no sound
Best to contact Polk's CS department on Monday at 1-800-377-7655 select option 1, they'll help out.
Thanks for your help !!
No problem...
I recently purchased the soundbar 4000 and I am not successful at setting it up. I have followed the simple instructions in the manual but am having no luck. I am attempting to use it without a remote. That wouldn't be a problem would it?
I don't believe using without a remote is a problem. What setup problems are you having?
I have yet to hear any sound from either the soundbar or the sub. There is not much to this equipment but I feel like there may be something else to try before giving up.
I'm using a cell phone and and auxiliary cord to attempt to play music. I have another speaker system that this setup works on. Is there anything obvious that I am missing?
It's pretty straight forward, you just need to make sure you have the bar set to the corresponding input you're using. If it still doesn't work you can contact Polk at: 1-800-377-7655 and follow the prompts.
