PSW12 LFE or LINE INPUTS
bumpnyota
Thanks in advance for any help. Just purchased the PSW12 today. Had to replace a Jbl pb12. I have an Onyko 601 receiver. Just wondering whats recommended a hook up to the LFE or line inputs with splitter.
Post edited by bumpnyota on
thank you all for the advice
brian -
You should try both ways and see what sounds best to you cochise.
I don't know how anyone can tell you set your speakers to small, without even knowing what you have.
Cheers,
thanks russ,
I have JBL satellites(mounted on walls) and a Onkyo 601. I had a JBL pb12 that gave up the ghost (believe the internal amp was culprit) i replaced it with the psw12 . The satellites are JBL northridge series N24's. I have four n24's front left and right and left and right surround and a northridge series center channel.
Any additional info is much appreciated.
P.s. The onkyo is capable of running a surround back speaker (6.1) will i gain by adding the additional speaker.
thanks
Brian -
Welcome, bny...
Most likely with satellites "small" is the way to go, but trying both is easy. You should go through calibration for both though, and that'll take a little time.
Adding a rear center will fill in your HT's sound field, and there are a few DVD's with separate rear effects info and many, many more to come...More later,
Tour...
Vox Copuli
