PSW12 LFE or LINE INPUTS
bumpnyota
bumpnyota Posts: 3
Thanks in advance for any help. Just purchased the PSW12 today. Had to replace a Jbl pb12. I have an Onyko 601 receiver. Just wondering whats recommended a hook up to the LFE or line inputs with splitter.
Post edited by bumpnyota on
  • PolkThug
    PolkThug Posts: 7,532
    edited October 2004
    LFE.
    On receiver:
    Set speakers to small, x-over at 80Hz.
  • gatemplin
    gatemplin Posts: 1,595
    edited October 2004
    I like the LFE too and I dont bother with the splitter.
    Graham
  • bumpnyota
    bumpnyota Posts: 3
    edited November 2004
    thank you all for the advice
    brian
  • RuSsMaN
    RuSsMaN Posts: 17,985
    You should try both ways and see what sounds best to you cochise.
    I don't know how anyone can tell you set your speakers to small, without even knowing what you have.
    Cheers,
    Russ
  • bumpnyota
    bumpnyota Posts: 3
    thanks russ,
    I have JBL satellites(mounted on walls) and a Onkyo 601. I had a JBL pb12 that gave up the ghost (believe the internal amp was culprit) i replaced it with the psw12 . The satellites are JBL northridge series N24's. I have four n24's front left and right and left and right surround and a northridge series center channel.
    Any additional info is much appreciated.
    P.s. The onkyo is capable of running a surround back speaker (6.1) will i gain by adding the additional speaker.
    thanks
    Brian
  • Tour2ma
    Tour2ma Posts: 10,177
    Welcome, bny...
    Most likely with satellites "small" is the way to go, but trying both is easy. You should go through calibration for both though, and that'll take a little time.
    Adding a rear center will fill in your HT's sound field, and there are a few DVD's with separate rear effects info and many, many more to come...
    More later,
    Tour...
    Vox Copuli
