External Rings..
Toolfan66
It's hard to capture the gloss black on these,
Not sure if they will have a negative affect on sound but it dresses them up a bit, and as always it's worth a try as I'm not out anything but time. Looking forward to having these hooked up again..
These are made of 6061 T6 Aluminum..
I think it looks sweet. Look forward to seeing a complete speaker.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
Looks nice! Larry.
It only took you what 6 years after I asked you about it. Put me down for a set for my 1C's. (powder coated)
“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Larry do they sammich to the inside rings?
I love the concept Larry, but I do think the screw heads should be countersunk and flushed, or have the rings be threaded through from the inside with no screwheads showing at all. Still trying to wrap my head around bolting things together however...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
AndI'll disagree with that. I like the contrast & the industrial look. But.
De gustibus non est disputandum.
Are they strictly decorative Larry, or do they exert pressure on the rubber surrounds when torqued down?Home Theater/2 Channel:
dhsspeakerservice.com/ -
I don't know if they add anything sonically but they sure do look nice.
westmassguy wrote: »Are they strictly decorative Larry, or do they exert pressure on the rubber surrounds when torqued down?
I don't think it really maters so as long as they don't interfere with the flexible part of the surround, They would keep one from over torquing the mounting screws and dimpling the baskets.
(One of these days I'm gonna learn how to speall).Post edited by gimpod on“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
I know diffraction is not as important on the SDA design but that was my first thought with these rings... now the stock grills are basically one big diffraction point, but my thoughts for the rings directly correlate to the tweeters
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
On the flip side, building an insert that brings the baffle flush with the grill... I think that would actually bring some nice positive improvements - kind of like the RTi series and their anti-diffraction baffles.
They look good to me...would look better if the screws were the same color.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Studying the pictures I can say they do not touch the rubber at all on the mid-drivers and maybe just slightly on the outer edge of the PR.Political Correctness'.........defined
President of Club Polk -
That's what I was getting at. The rubber could actually move or creep under stress, and buckle up.westmassguy wrote: »Are they strictly decorative Larry, or do they exert pressure on the rubber surrounds when torqued down?
These do not touch the rubber at all, and I don't think that would be a good idea, I could see it becoming a very big issue down the road if not right away..
Excellent. That was my only concern Larry.These do not touch the rubber at all, and I don't think that would be a good idea, I could see it becoming a very big issue down the road if not right away..
They look sweet!
That's sexy and so clean....looking forward to the top and side mods.
Are you making matching tweeter bezels?
...for good reason you're fidgeting
....just a couple more days 2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I'm not happy with the tweeter bezels, I'm going to leave them stock for now..
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
So is the passive, and x-overs
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
