What Are You Listening To?
1…13571358136013621363…2078
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
  • Unknown
  • voltz
    voltz Posts: 5,384
    todays dollar vinyl pickups;
    the Veejay Beatles is in of course fair condition and mono, as is the other Beatles Lps
    The Led Zep is in good condition and I believe the A version.
    Steve Hillage is an upgrade
    Whats in the Paper bag???
  • voltz
    voltz Posts: 5,384
    The Doobie Brothers * Toulouse Street *
  • BlueMDPicker
  • [Deleted User]
    [Deleted User] Posts: 10,716
    $1.60 CD;
  • aprazer402
    aprazer402 Posts: 3,463
    c0i3z0slzbrm.jpgRIP Gregg
  • BlueMDPicker
  • pumpkinman
    pumpkinman Posts: 10,491
    CD's tonight
    Dust • self titled
    Because I am The Pumpkinking
  • [Deleted User]
    ^^^^ vinyl on now.
  • Gatecrasher
    Gatecrasher Posts: 1,538
    This morning I've been doing some testing of my CDs versus Spotify. I have been curious to find out if Spotify increases the levels on its music files to make all the levels similar and louder. A leveler program can bring up the lows and make everything in the music track sound louder. This is frequently done with "remastered" pop music. I read an article on this and it showed how Michael Jackson's "Bad" Lp has had this done to it in 3 different "remasterings." Another example of this is ELOs "Out of the Blue." The remastering has added much more lower end bass to the music than the original Lp.
    Part of what I like about my RTI A3s and A5s is that they remain clear and detailed with the quiet passages of classical music. I just compared the adagio in Symphony 4 (Karajan Beethoven 1977 cycle, from his Symphony edition, on CD) to the same track at Spotify. I also have this same symphony cycle on Lp records. That track starts off quiet and gets much louder at about the 48 second mark. The Spotify track did not sound louder in the early quiet part of this track and sounded just as loud as the CD in the louder parts of the track. I like the wide dynamic range of classical music.
    I recently listened to most of Frank Sinatra's catalog at Spotify and some by Dean Martin. Both of these artists music have much more dynamic range than modern pop/rock and I turned the volume up almost the same as with classical music.
    That's the main thing you have to take into consideration when doing any comparisons. You need to make sure you are comparing apples to apples and use the same version CD as Spotify is playing because they are all remastered differently.
    You can take a newly-remastered classic rock album and rip it to MP3 and then compare it against the original CD release in lossless format and the MP3 can sound better in many instances.
  • pumpkinman
    Buddy Guy • Heavy Love
  • Unknown
  • HzTweaker
    HzTweaker Posts: 1,136
    Gorillaz Humanz Delux. 96kHz/24bit. Playing over a pair of craigslist CRSs with RDO-194s.
    2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    Standby: Magnepan LRS w/Magna Riser stands
  • HzTweaker
    Mad Season Above (Deluxe). FLAC On The CRSs.
  • lunazul
    lunazul Posts: 781
  • BlueMDPicker
  • Unknown
  • pumpkinman
    The Section • Forward Motion.......WLP
  • pumpkinman
    Herbie Hancock • Thrust
  • [Deleted User]
  • pumpkinman
    Allan Holdsworth • Velvet Darkness
  • dromunds
    dromunds Posts: 10,174
  • [Deleted User]
    ^^^^ SACD now playing
  • [Deleted User]
  • dromunds
  • lunazul
    lunazul Posts: 781
  • [Deleted User]
    US cleaned Vol 1 side 1;
  • pumpkinman
    The Dimes • The King Can Drink The Harbor Dry........Spotify
  • BlueMDPicker
