Power Circuit Upgrade
machone
I just finished closing the wall to an upgraded power circuit for my 2 channel system.
I installed a sub-panel with four 20 amp dedicated circuits. Each circuit has 10/2 MC cable feeding two duplex hospital grade outlets.
The panel is fed via a 60 amp breaker with #6 wire and has a #4 solid wire ground.
In addition the sub-panel is protected with a panel mounted surge protector.
I sold my Tripp-Lite 2400 (with noisy transformer) and am plugging everything directly into the wall.
I separated my components between the four circuits as listed below:
1. Amplification
2. Analog
3. Digital
4. Video
I am very happy with the results.
I seem to drawn into the music no matter which source I select.
1. Amplification
2. Analog
3. Digital
4. Video
1KVA Dreadnought
Marantz SA 8005
Sony PS4
1KVA Dreadnought
Marantz SA 8005
Sony PS4
I'd still use a power conditioner for everything but the amps and subs.
Just my opinion, but I think you actually have less protection for your electronic components with the whole house type surge protector than you did with the Tripp-Lite, providing it was in good working order. -
1. Amplification
2. Analog
3. Digital
4. Video
^This is cool. When I grow up and buy a home I'm going to install a similar setup.2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
You must have missed the part where he said the subpanel has a panel mounted surge protector... which means the entire panel (and anything running off it) is protected.
I have one on my main system and have 3 dedicated lines for my HT and the main reason I still run my ALC H15 is because it has more outlets than the regular wall."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
That's drool-worthy. I was so happy to install two 20 amp circuits in mantown in VA, I didn't dream of anything like this...
All the while my electrician, a very nice Russian fellow saying... "you know... this eese something you do not neeed... eet eese in your head... not your earrsh."
Yea, I've heard it before, just install it baby! Difference? Fo Sho!! Congrats!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
ThanksMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
When I build my dedicated HT I want my system...
Where do I get one?...protected with a panel mounted surge protector.
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Lowes, Home Desperate, electrical supply house, Menards......
New Orleans? I can have it installed in a jiffy. Just ask @EndersShadow........ -
I have a HD & 2 Lowe's w/in ~15-25 minutes depending.
ThnxSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
As others have said "Lowe's/Home Depot, etc".
Mine fit the sub-panel and took up two circuit breaker slots. If fitting into a panel make sure the surge protector is compatible with the panel.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Nice job machone! Whole House Surge Protector here also, I wouldn't be without one, if at all possible.
@machone why seperate the components that way?
afterburnt wrote: »@machone why seperate the components that way?
No cross noise contamination. Each will have its own dedicated circuit. -
FWIW: I have my left* & right** tower amps on separate breakers.
* shared by the CC amp
** shared by subSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Last night I upgraded two outlets with Furutech copper outlets. One for my amplifi cation and one for digital. Got them from Doug.
Had a great listening session afterwards.
I plan to upgrade the power cords to the preamp, computer power supply and Marantz 8005 next.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Looks right purdy!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
We have the Furutech FPX-CU receptacles on sale right now. And as a Polkie you'll get another 10% off. Click on contact us and give me your Club Polk handle along with what you want to order. We have a lot of goodies on sale right now, so check out the specials page.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
If there is anyone on the fence thinking about an receptacle upgrade I recommend trying the Furutech FPX-CU.
I must say I have been pleasantly surprised that this could really improve SQ. Seems to be more air around individual voices and instruments with tighter bass and a sweeter presentation.
Sure would like to hear someone else's experience on this to verify that I am not crazy.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Recall the $? Hypothetically I need 5Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Doug provided a link to it
http://www.douglasconnection.com/Furutech-FPX-Cu-Duplex-Receptacle-FURUFPXCu.htm -
Make sure you also upgrade the wire leading to the panel box, and the breaker, and the panel box itself, and the cable leading to the meter, and the meter pack, and the meter, and the drop from the transformer. Also, make sure all of the power lines from the transformer back to the power generating plant are upgraded. -
Already Done!
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Already Done!
I just thought of something. Are the ground conductors in the MC isolated from the junction boxes? Are the receptacles? Inherently, the metal armor is grounded to those boxes and the panel box. -
Very nice!
The MC metal armor is grounded to the sub-panel but the receptacle box is plastic.
The MC ground conductor is grounded to the sub-panel and the receptacle.
I got a lot of good info from the attached White-Paper.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
That sounds like the most ideal method. I had never seen MC run to a plastic box. That's why I wondered.
Already Done!
You're welcome. -
1KVA Dreadnought
Marantz SA 8005
Sony PS4
I continued to upgrade the power circuitry. I added new power cords for the Quantum Byte/Mojo power supply, Marantz SA8005 and Hafler DH110 preamp.
I used Furutech FI-11M and FI-11 connectors along with Furez FZ100BS sleeving. Got these from Douglas Connection.
I combined these with 12awg shielded cable from VH Audio.
It took a while to burn in but the results are outstanding.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
