Sonos Connect: Amp??
Is a Sonos Connect: Amp enough to power my Polk Audio TSX 550t?
Tower speakers for master bedroom.
Thanks!
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
    txcoastal1 Posts: 13,519
    No sir
    Own 2 Sonos connects
  • Kingkwas
    Kingkwas Posts: 92
    Would a Def Tech W Amp perform better?
    R: Def Tech
    DVD: Oppo UDP 203
    Kingkwas wrote: »
    Eh, not really. Those type of devices are meant to drive bookies, not floor standers. Not with any authority anyway. Use a decent receiver or move down to easily driven bookies if you want to go that route.
  • vcwatkins
    vcwatkins Posts: 1,992
    edited May 2017
    Not sure it'll be helpful but...I have one Connect Amp. It's currently powering Infinity Primus P-152's in the beach garage. Never really pushed the volume in there, but they sound very good and I think they would be just fine at higher volume. I believe they are 88-90db.
    I've also run DefTech SM45's (90db IIRC) and even Polk 11T's (90db maybe?). Again smallish room, good sound, lower volume levels.
    Forgot to mention that this is an old Connect - probably 1st generation. Not sure if/how the specs may have changed through the years.
    If all you want is lower volume sounds, then you can get by, but I think we all tend to push those limits at times and that's when trouble starts if your not in tune to whats going on with that speaker/power relationship.
    It's not that you can't, just a recommendation I wouldn't make, especially to those who may get the urge to exercise that volume dial.
