MIT Shotgun series cables
kevhed72
Looking for a bit of advice, as I know the Shotgun series speaker and IC cables supposedly work best when all cables in the system are of the same series....i.e. S1, S2, S3. Also, This next purchase would be for a set of balanced S2 IC for the pre to amp connection. My speaker cables are S2 series biwires and perfect length. The other ICs are S3 from DAC to PRE and also have a set of S1. I really want to go all the same series at this point, somewhat because of mild OCD issues....roll with the S2 blalanced pair and sell the S1 or S3 to finance these...thoughts?
I've used many variations of MIT cables, different series as well as all the same. Sonically, I find it better to mix and match levels.
Through much trial and error I am not a believer in a full loom from the same manufacturer. Others have a different POV. It has just never worked for me. YMMV.Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's -
Kev, you must surely be experiencing absolutely unbearable, horrible sound with that mishmash combination of MIT cables, making you want to put all your stuff out by the curb on trash day.
(I can relate to this neurosis)
What are the balanced S2s replacing?
I'd probably put the S1s on the DAC to Pre, and move the S3s.
Be good if someone could comment, designwise, on what the S1s have over the S3s, but seems to me, putting the best of the three in place would eliminate any potential signal limitations at the source, so you're not passing a "degraded" signal to the rest of the chain from the get-go? Of course, best to test for yourself to see how you like each if you can get the S2s before selling the S1s or S3s.I disabled signatures. -
The balanced S2 would be replacing unbalanced S1s going from pre to amp...I know, I have issues..,
You have issues? I don't think you have issues….
^^^ lol, nice, man
Who cares about pool anyway.
Nah Kev, I see where you're coming from. I prefer balanced between the pre and amp, myself. Aside from the obvious dB bump I notice, I would be curious as to whether I could pick up any SQ difference between balanced and unbalanced.
So you currently have S1s in the front end, and only S2s from the amp to speakers? I see your dilemma and considerations here. I'd be questioning whether to move to S2 from S1 as well, even if going to balanced. Certainly does invite more question. Any chance of holding out for finding balanced S1s? Of course then you'll be wondering how much better your speakers could sound with S1s there...
It's obvious that these changes are disrupting your peace.
Now I'm getting sucked into it. I hate your guts.I disabled signatures. -
At least you covered your pool table! Is that a PS Audio AC5 I spy in the middle....You have issues? I don't think you have issues….
That is a PS Audio Statement. Works great on my stereo amp but I am using mono's, plus it is one stiff cable.Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's
What I did swap out today was a Black Cat digital coax for an AQ VDM 3 between the DAC and CDP. That and mixing 2 different tubes into the compliment of 4 in my Cary pre was a pleasant surprise.
Nice, tube rolling can definitely change the tone and presentation. Is the Black Cat made by Stereolab?Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's
Black Cat was a line of cables by Chris Sommovigo.
Kev, presuming this was a Veloce you swapped out?
I just recently obtained a nos one of these after 2yrs on the lookout.
Mr. Sommovigo moved to Japan and is still building. Interesting fellow; cool philosophy on life and living. Serious about cables.
https://blackcatcable.com/pages/aboutI disabled signatures. -
Good to hear about Chris, I have a Stereolab Diablo SC that I swap in from time to time. It is interesting as it has the equivalent of 32 AWG or something similar, very thin but I would not characterize it as lean. I used to have his 600 silver SC but sold it.
I mixed different series of MIT in one of my systems and sounded quite pleasant.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
It is....it popped up on US Audiomart so I jumped on it. When I tried it vs. my generic glass Toslink coming from the the squeezebox there was barely a difference. When I hooked it inline to the CD player is really where it really became noticeable.Black Cat was a line of cables by Chris Sommovigo.
As they are all Shotguns they are the same series just different levels. Since it appears your gear is not a balanced design I don't think you'd gain anything going to the balanced IC, but I also don't think you'd notice much difference going from the S1 to the S2. Certainly not as much of a difference as going from the S1 to an S3.
If you ever want to sell the Statement power cord I'm interested as long as it has the removable ground pin. -
The PS Audio Statement does not have the removable pin.Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's
Ok, thanks.
2 channel:
Theater:
LOL.....no the reason is the early Statement cords didn't have very good grip on the IEC end. PS Audio improved that and also added the removable ground pin. That's how to tell if the IEC end is the death grip version.
ah I see, I also enjoy the death grip. You could hang off a building with the furutech stuff.2 channel:
Theater:
Did you buy that just recently from a guy named Frank?
Unfortunately my Polks are right in front of the amp plugs so for me to use the PS I must have a severe bend because of the speakers close proximity to the wall. 8 inches - thats about as much as it will bend.Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's
