How to add album artwork to files in Foobar2000?
gudnoyez
Ok I am probably an idiot how do I add album artwork to my files in foobar2000? I like how the program works and sounds but it looks so basic and blah. Is there a foobar2000 for dummies website?
Ok I think I figured it out I need to go to album art exchange download a 600x600 image of said album go to album right click add front cover to file in foobar2000 sounds like a lot of work, there has to be an easier way or else I will be busy doing it like that.Home Theater
Steve, not sure of a quick way in Foobar, but I think there are a bunch of programs out there you can use for this. It can be done outside of Foobar just for the cover art, and you can keep using Foobar for everything else, if that's what you prefer.
Here's an example. I haven't tried this one, but could be an option for you. https://sourceforge.net/projects/album-art/
This is another one I heard about through THJ and WMG
http://www.muvenum.com/products/muvundercover/
Speaking to your note re: Foobar being no frills, I've been using Music Monkey lately, in general. I like it a lot. Got a lot of functionality built in, and customizable. Bit of a learning curve, but worth it, I think.I disabled signatures. -
Thanks I will check into those, as doing it the way I found is going to take forever.Home Theater
Until I realized that my existing program added album artwork from the start, as I wasn't clicking on that option, and several thousand albums later, I bought the muvundercover program that I learned about here, and it worked well. Now I just add the artwork at the same time I'm adding albums and everything is good."if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
No I haven't. I've been using Music Bee. Music BEE.I've been using Music Monkey lately
wtf, smh. I'm too young for that to be happening. Must be some other kinda Monkey I'm using for something.I disabled signatures. -
I figured it out no downloading pictures necessary, all you got to do is click the view menu, select layout , quick setup, visulation cover art quick appearance setup window then click OK. Wala picture art, media data and some graph bar two lines saying flac 841kbps. I'm a happy camper tunes and no fussing about digging this foobar2000 player. Time for some tunes.Home Theater
Steve, is that for ripping? I just use it for a player and never much explored its capabilities.
Playing back the flac files. its an awesome all around audio player, haven't tried ripping with it yet Bruce.Home Theater
I was wondering if does in fact rip, I use EAC for ripping. Try it with that Fidelizer thing, it makes my pc sound better.
Steve, is this just for new rips, or does it also pull down art for an existing library?
After thinking I was clever with my 256kbps VBR mp3s for so many years, I have to admit, it's been really nice enjoying .flac recently as I get into it as well. Not just seeing the higher bit rate and .flac, but obviously, the sq improvement. I have to shake my head at myself for not doing this sooner. Plus, it's fun.I figured it out no downloading pictures necessary, all you got to do is click the view menu, select layout , quick setup, visulation cover art quick appearance setup window then click OK. Wala picture art, media data and some graph bar two lines saying flac 841kbps. I'm a happy camper tunes and no fussing about digging this foobar2000 player. Time for some tunes.I disabled signatures.
