Monitor 10A speakers, mine at last!
Yes looks great!
my 3.1TLs
I will fix your shifted magnets for free.
Thanks. I have some stains of the PowerGrab on the magnet. How can i removed it? Do i need to do it?
First, you'll need the proper equipment: a crowbar, a bolt cutter and a full set of well-lubed, 30-weight ball bearings. Oh, and one can of ripe black olives.
J/K
You're doing just fine.
Report back on how they sound, post upgrade/mod.
Dear all, i need advise on which amp i should buy? Should i.....
1) Buy 2x Rotel RB970BX MKII @$300 (Run as Mono block)
2) Just buy a RB960BX @$80
3) Save $$ to buy a higher pwer amp.
Which one do you all suggest?
My current setup:
1) Azur 651C
2) GDA600 or MSB Link
3) B&K Reference 5 Series 2
4) Adcom GFA 535II
5)SDA 2B
